Results 1 to 25 of 25
Thread: Put a Mustang transmission in my Daily Driver Lexus? Why not? (Video)
    Bamskee DarkTactics's Avatar
    Macomb, MI
    3,176
    Steam ID: Ruiner
    2002 Lexus IS 300 with a GTE swap running a Precision 6266 with supporting mods. Car was meant to just be a good daily driver which turned into "sleeper" more often than not. Wastegate is recirculated, still has stock muffler with a vacuum actuated dump just before it.
    It's the first IS in the world with a Mustang 6R80 transmission (6 Speed Auto). I do hope to get some higher quality video soon. Hard to do it yourself.
    • Quick Spool Valve, T4 Log Manifold, Gen 2 Precision 6266 Turbo
    • AEM Infinity ECU
    • FACTORY shifter (Leveraged a Fox Body Shifter Cable)
    • FACTORY steering wheel shift buttons (For Manual Shifting)
    • Everything is bolt in (Can literally swap this to any other IS)
    • Custom Trans mount
    • CCI Custom 3.5" Aluminum Driveshaft
    • Circle D Custom Torque Converter
    • Used 6R80 with Custom Billet Bellhousing
    • US Quick Shift 6 Trans Controller, tied into to AEM Infinity
    • Rear Mounted Trans Cooler
    Car made 500+whp at 19PSI. Breaking in this setup and working out any kinks over the Michigan winter, and will turn up the boost once spring hits
    (My buddy alex who helped make this a reality)
    Registered Member Black96lt1's Avatar
    G'vlle,SC
    17,333
    2261
    Gamertag: Gameskin
    That's a pretty cool little sleeper
    better than Bryce silverSS's Avatar
    29,237
    I guess my only question is "why"? Definitely cool though.
    LIFE IS GOOD HybridZ28's Avatar
    DFW, Texas
    29,030
    237
    Pretty sneaky with that black front mount. I like it!!
    R.I.P PCED: 6-28-2020 5.0THIS's Avatar
    43,961
    31500
    Seems like a ton of work. I would have just LS swapped it for half the cost and effort.
    Registered Member torch318's Avatar
    May 2015
    637
    So how are you controlling the trans?
    Sent from my SM-G950U using Tapatalk
    Macomb, MI
    3,176
    Steam ID: Ruiner
    Quote Originally Posted by torch318 View Post
    It's in the list and video. US Quickshift Trans Controller pretty solid unit, plugs right into the trans, and just had to wire a few things into it. (RPM, Shift Buttons, Manual Button, etc)
    90,942
    50
    What was the reason for the trans swap? Is the FoMoCo unit stronger or quicker shifting than the Lexus trans? Would the stock unit not hold up to the power level you are hitting?
    Whataburger > *
    Dr Griswold's Avatar
    109,607
    Badass. Swaps FTW
    19,158
    Sweet
    SPECIAL DARK HOTCIVIC's Avatar
    KFC
    24,728
    3000
    179,466
    Quote Originally Posted by windham View Post
    I was wondering this, as well.
    Macomb, MI
    3,176
    Steam ID: Ruiner
    Yep, big time. The 6R80 is good for 700WTQ in stock form and about 1K hp. The factory a650 even after being built pooped out after 2 months of driving at only 19PSI (550whp).
    Especially around Detroit, I have a trans that I can find plenty of parts / replacements / etc for, and it is a 6 speed. The shifts are definitely faster and keeps me perfectly in peak power band which is huge.
    The biggest advantage is old trans tech vs new...
    I have full control of shift points, shift firmness, TCC lock, a transbrake is built in, and I can switch performance maps on the fly. (So it can be like a factory luxury car, or full race mode)
    90,942
    50
    Quote Originally Posted by DarkTactics View Post
    Sweet
    179,466
    thanks for the explanation.
    Custom User Title Hobbes's Avatar
    Gone Fishing, CO
    13,343
    331
    Wow, that's really impressive. Your car(s) are sick
    Macomb, MI
    3,176
    Steam ID: Ruiner
    Quote Originally Posted by Hobbes View Post
    Thanks! I think I have a problem, as the fleet is rather large, and I don't wanna get rid of any until I know what I'm doing
    43,961
    31500
    Yeah the whole multiple 3000GTs thing is.... strange.
    But you like fast cars so it could be worse.
    I mean at least you don’t own a Toyota landcruiser.
    Registered Member Fastpace's Avatar
    Houston, TX
    2,887
    Gamertag: FASTPACE1105
    Would be strange for a normal person but not for OP.
    Darktactics, how many 3/Ss have you owned or had possession of? I think by the time we were out of high school you were over 10.
    Sent from my SM-N950U using Tapatalk
    29,237
    I always wanted a Stealth RT/TT but the horror stories kept me away. Now they are all either beat to shit or never driven and crazy priced.
    43,961
    31500
    Quote Originally Posted by silverSS View Post
    I always seem to be shopping vehicles that fall into that category.
    Macomb, MI
    3,176
    Steam ID: Ruiner
    Quote Originally Posted by Fastpace View Post
    Oh man. I've probably owned 40-50 at this point. There are others who put me to shame nearby, but it helped pay for college and helped me keep a healthy collection of spare parts. I honestly need to figure out which ones to keep.
    91 VR-4 - first car I ever owned... do you really get rid of that? (I've been leaning more so ever than before)
    97 VR-4 - perfect amount of mods. Perfect driver. 76k miles.
    99 VR-4 - 11k original miles, fully built stroker motor, needs some work, but 11,209 ORIGINAL miles, I'm the second owner. 1 of 287 in existence.
    95 Stealth - The only car I have with the pop out roof... 86k miles.
    Registered Member Jake the SSnake's Avatar
    Apr 2005
    Iowa
    23,064
    Gamertag: xJAKEtheSSNAKEx PSN ID: JaketheSSnake
    What's wrong with Land cruisers?
    43,961
    31500
    Quote Originally Posted by Jake the SSnake View Post
    Somebody has to be anti- landcruiser/scion to counter all of Rich’s spam.
    Apr 2005
    Iowa
    23,064
    I think he's probably the only one that isn't anti scion lol.
