Results 1 to 18 of 18
Thread: Need assistance troubleshooting a intermittent check charging system indicator.
    28,011
    193
    Car: 2012 Enclave 2wd
    Battery tested at 13.9 volts
    Alternator test successfully
    The battery light and "check charging system" text appears on the dash, the battery voltage gauge also drops below 10 volts. I've already replaced the alternator and the battery twice(under warranty). Got any ideas on what is causing the system to think the battery has low voltage? We tested the battery at the battery and not using the terminals under the hood. Its getting frustrating as hell. The car has 91k miles.
    I hate this car, probably the last GM vehicle I'll own.
    No ragrets Tristan's Avatar
    In a van down by the river
    89,661
    1025
    Loose connection. Check battery cable and alternator cable.
    28,011
    193
    Quote Originally Posted by Tristan View Post
    I'll double check them.
    13,159
    1283
    Body Control Module? The reading I did the other year is that's linked to all kinds of big & lil issues with those cars
    28,011
    193
    Quote Originally Posted by runningmole View Post
    Is that in the ECU?
    "What up 2-1-2" Locker537's Avatar
    MA
    15,273
    Gamertag: Locker537
    In addition to a loose connection, check for corrosion on the battery cables? Sounds obvious, but I remember my wife's Jeep having crazy symptoms and that was the cause.
    F*** Islam BlazedTech's Avatar
    Wylie
    4,481
    Don't forget the ground side. Check the grounds from the battery and well as engine and chassis grounds.
    28,011
    193
    Quote Originally Posted by BlazedTech View Post
    got any idea where they are located on a Enclave?
    Quote Originally Posted by Locker537 View Post
    two brand new batteries have been used.
    Goodyear AZ
    4,944
    17875
    Take a look at this and see if you think it's relevant, it's for a Acadia
    https://ricksfreeautorepairadvice.co...ystem-message/
    I think my next step would be using a scan tool and driving it while observing the signal to the BCM.
    28,011
    193
    Quote Originally Posted by 1STLS1 View Post
    I do not have that type of equipment so I guess its off to the dealership.
    Goodyear AZ
    4,944
    17875
    I have been wondering how this worked out?
    28,011
    193
    Light hasnt came on while I've been in the car to monitor it.....
    28,011
    193
    I had the dealership check it out. They think its the Auto-Zone alternator intermittently failing while driving.
    Goodyear AZ
    4,944
    17875
    I have heard numerous situations where a aftermarket alternator does not work correctly with the vehicles programming, Nissan, Ford and Mercedes have this issue also.
    Bench test it, works great, trying to get it to interface with the vehicles computer that works off a specific resistance or it's out of it's range by just a little and it faults out or doesn't function as it was designed to do.
    20 years ago, yeah, check the sense wire or ground, today's stuff is really advanced
    28,011
    193
    that makes a bit of sense because the light hasnt came on since I made this post.
    Registered Member FirehawkNS's Avatar
    Charlotte
    30,883
    14525
    It's almost annoying how advanced, yet how useless the codes can be now compared to what I remember in my older vehicles.
    We have been dealing with all sorts of pulsing issues in the wifes car. SES lights randomly. I basically got it down to just the P1101 code which points to the MAF. Sometimes. Or it's the Crank position sensor....or the VVT sensor...or....
    So I have replaced the MAF, the Crank sensor....on to the VVT sensor I guess.
    I feel like in the past I always had a code that was pretty spot on to the issue, now it's like "it's one of these 10 interconnected things...good luck" :/
    28,011
    193
    Quote Originally Posted by FirehawkNS View Post
    I feel the exact same way. Unless you have an professional code scanner, the codes me jack shit.
    Registered Member shuck's Avatar
    Everywhere
    45,547
    15011
    Quote Originally Posted by mogs01gt View Post
    I bought a BT OBDII module that plugs right in for $60. I got it for the track so I can record data but it works great as a scanner. You can download an app that will allow you to read and research the codes, reset them and all of that.
