Results 1 to 6 of 6
Thread: Squeaky brakes
    Patronist esandes's Avatar
    Canada
    7,154
    746
    Squeaky brakes
    What's the cause for pulsating scratch sound when braking?
    Warped rotors? I recall it still happened even after new pads and rotors?
    The sound frequency is proportional to the vehicle speed.
    13,114
    1283
    Slide/guide pins could be gunked up or need grease causing uneven pad wear
    Canada
    7,154
    746
    Thanks. I'll put some lube on.
    Starminator Wars 2: Judgement Force ScotWithOne_R/T's Avatar
    Twin Cities, MN
    26,138
    2725
    Raptr ID: WhatinthefuckisRaptr
    Could be the sheet metal dust shield. I've had one somehow get bent and rub on the disc.
    Canada
    7,154
    746
    Quote Originally Posted by ScotWithOne_R/T View Post
    That's what I was thinking. I changed the tires (winter and summer) dozens of times and I sometimes hot that metal with the wheel.
    106,858
    Update?
