Results 1 to 6 of 6
Thread: Brake fluid replacement on car with traction control
    "What up 2-1-2" Locker537's Avatar
    MA
    15,205
    Gamertag: Locker537
    When referring to the service manuals I have, they recommend bringing the car to the dealer with a proper scan tool to replace the brake fluid if your car is equipped with TCS.
    I did some quick searching, but would love if someone had first hand experience with this here.
    27,675
    193
    Drain a most of the fluid, put new fluid in, bleed the brakes until the new fluid appears, put more fluid in.
    Probably like 25 minutes worth of work.
    It'll get ya fat KrispyCharger's Avatar
    Detroit
    34,895
    11959
    You can still bleed the brakes, but if you have air in the ABS module you may not get it out without being able to activate the module like the dealers can.
    106,858
    Quote Originally Posted by KrispyCharger View Post
    24,220
    7534
    I've never had an issue but if you're anal go stomp on the brakes on wet ground to trigger the abs, then re bleed.
    MA
    15,205
    Gamertag: Locker537
    Thanks, sounds like the tip is to be cautious and ensure you don't introduce air.
