Results 1 to 28 of 28
Thread: Z06 spun the reluctor wheel?
    Twerkin 4 dat BigMac Roger Z06's Avatar
    Sep 2008
    Waveland Mississippi
    39,805
    102
    Gamertag: Roger Z06 Vette
    Between my 2nd and 3rd pass at the track I yanked the air filter to see if I could get a 10.70 out of it on the motor. It 60íd and then fell on its face. Would only go 1/2 throttle and drove it home normally ... just couldnít go wot. No codes. Got worse over the next week and eventually would only idle.
    When you would give it throttle it would lose ground on the injector (conformed via noid light Ņsp? then a fluke) via the computer.
    Threw another computer in it and tried to crank relearn since it was now throwing a crank sensor code ... no dice ... new sensor ... no dice ... ohmíd wires between sensor - computer and looked it over visually ... all good.
    Now when it starts up it is down two cylinders (4&7) they are getting spark but the injectors are not pulsing. Since both spark and injectors are run via crank signal as well as rpm and Iím getting a consistent rpm it leads me to believe the reluctor spun on launch.
    Thatís all I can come up with. Weíve looked at it via bore scope through the sensor hole and itís still on there but who knows if itís still degreed correctly without pulling the engine.
    So here I am
    Just like ... fuck it ... only the 7th or 8th time the engine has come out.
    02c5z EBM
    408 Callie crank Manley rods diamond pistons with a moneymaker intake manifold. It did good when it did.
    Iíve finally started to fuck with it the last couple months and thatís where Iím at. Figured Iíd see if anyone in our circle has any idea.
    28,768
    5075
    I can't say I've ever heard of that and this link makes it look like there's no real reason it would move on it's own assuming it was installed straight.
    http://www.superchevy.com/how-to/eng...-your-ls-crank
    86,582
    900
    Quote Originally Posted by Potent68 View Post
    So.you are reluctant to agree with his diagnosis?
    Sep 2008
    39,805
    102
    I feel like it’s a pretty common issue if you search it. At least when you make decent power.
    The Sax of Cars Anewconvert's Avatar
    Jul 2005
    Raleigh, NC
    16,100
    1301
    Quote Originally Posted by windham View Post
    ISWYD
    23,764
    It is known to happen, especially shop builds where it's only held in place by a couple tacks vs OEM. Have read a couple threads where given a choice for high power builds 58x reluctors are preferred because I guess they're less likely to break loose. When you look into the ckps hole, can you also spin the motor over by hand? See if it has visible runout/wobble.
    Also don't think you can do a CASE relearn with an existing ckps code as it won't complete the process.
    Did you lose the tach signal at all? Was having issues with my new motor build last year and had a hard time keeping it running and tossed a random ckps code (0334 maybe?), tach died while driving. 3 tries to get it restarted which according to Tech was because the ecm then moves to the cam sensor for cranking. Once the tune got sorted out that all went away.
    Sep 2008
    39,805
    102
    Quote Originally Posted by NHRATA01 View Post
    Rpm is fine
    All coils are firing
    Only issue is #4/7 are not injecting.
    Registered Member Mr. Negative's Avatar
    New Jersey USA
    8,402
    6500
    A cam/crank correlation test with a scope would confirm this before pulling the engine.
    Goodyear AZ
    4,831
    10375
    Quote Originally Posted by Mr. Negative View Post
    This
    28,768
    5075
    If it's only two cylinders I doubt what I am about to say is applicable, but how is your fuel pressure? Your symptoms at the track and on the way home could be indicative of a failing pump or plugged filter.
    Sep 2008
    39,805
    102
    When you say scope, do you mean actually inspection of the reluctor through the crank sensor hole or do you mean HPTuners?
    Fuel pressure is good even on mechanical gauge.
    When it would “lay over” it was shutting injectors off ... like taking the ground away. You could see it with a noid light (which I assumed it was losing power... no... it was losing ground)
    To be fair
    I’ve never heard of reluctor wheel issues on stock or stockish engines. Only when they get to making decent power/torque. My engine was assembled by Futural in Louisiana which is a pretty reputable builder of some badass bullets.
    Sep 2008
    39,805
    102
    I was wondering if there was anything I could do to confirm this via putting it at TDC and seeing where the reluctors teeth were in correlation to the sensor but I doubt it would be even noticeable if it was possible. We are talking as little as 3*
    Goodyear AZ
    4,831
    10375
    https://www.snapon.com/Diagnostics/U...orrelation.htm
    There are other tools that can do this.
    As for 4 and 7 not being triggered from the ecu, I would pin the harness out from the injector to the ecu. With as many times as the motor has been out, it could be something simple like a connector pin just not making the circuit.
    Sep 2008
    39,805
    102
    Quote Originally Posted by 1STLS1 View Post
    The main harness we have inspected. From the coils on is yet to be done ... will happen before I pull it again.
    better than Bryce silverSS's Avatar
    28,126
    4000
    sounds to me like that shit may be broke
    Registered Member easttexasws6's Avatar
    Oct 2004
    TX
    10,065
    Sounds like it's tyme for a couple hiroshima hurricanes to pick up the slack of those 2 lost cylinders.
    Sep 2008
    39,805
    102
    Quote Originally Posted by silverSS View Post
    The reluctor wheel is fine
    We looked at it with a scope and spun it over by hand to see the rest of it.
    Whether it’s moved 3degrees who knows ?
    105,265
    11525
    definitely needs a couple teriyaki tornados
    preferably in the 98 flavor
    What the cluck? GldRush98's Avatar
    Springfield, IL.
    52,688
    3286
    Gamertag: GldRush98 Steam ID: GldRush98
    It's beijing bomb time
    26,759
    409
    Quote Originally Posted by Roger Z06 View Post
    Would three degrees prevent 2 cylinders from firing but allow the rest to fire normally, that doesnt seem right. Have you visual confirm those cylinders are getting spark and fuel?
    86,582
    900
    Maybe some Tokyo Twisters
    105,265
    11525
    Goodyear AZ
    4,831
    10375
    Ouch!
    The pin definitely fell out of that grenade. Makes note to self "29 psi max!!"
    KFBR392 87f383's Avatar
    117,402
    5
    5217
    I concur that you should try a set of Nagasaki Noisy Bois.
    Sep 2008
    39,805
    102
    Quote Originally Posted by mogs01gt View Post
    Yea seems pretty dumb
    I have confirmed the 4/7 are getting spark but not injector via noid light.
    26,759
    409
    I know this is PITA to do but I'd pull out the injector to make sure its firing. Once you confirm spark and fuel, you know its a timing issue.
    Goodyear AZ
    4,831
    10375
    Pin the harness out on 4 and 7, ecu to injector, meter it and check for an open. Back probe the connection at the ecu and see if you get the ground signal when cranking.
    I used to keep all the cuttings of open wires i found in harnesses that I had to splice. Insulation intact, looks fine but if you would pull on the 2 ends it would get thinner in an area. Meter it and they showed open. Makes for a long day the first time you see it but once you recognize the symptoms you can get it down to an hour or two. Inspection isn't good enough, meter it.
    86,582
    900
    Ouch!
    Gonna have to overnight parts from Japan.
