Results 1 to 29 of 29
Thread: Cylinder head re-surfacing
    Patronist esandes's Avatar
    Canada
    7,167
    746
    There's a lot of opinion on re-surfacing aluminum cylinder heads when removing the head for re-building (valve job or cam swaps). It's a 50/50 mix of folks who say you need to and you don't need to.
    The most convincing arguement I heard was from a professional drag car builder pushing 1000+ HP engines who said he never does. It seems like the machine shops and crooked mechanics suggest re-surfacing every single time the head is pulled.
    I'm not talking about overheating or blown head gaskets.
    This one's for you, Nell cuda6pak's Avatar
    Nashville, TN
    9,140
    1705
    Discuss
    discuss
    IG: eightyfivesquared 70Chevelle's Avatar
    22,812
    4850
    Gamertag: Ls1Chevelle
    I wouldnt do it unless it needed to be done
    Registered Member easttexasws6's Avatar
    Oct 2004
    TX
    11,458
    85
    Quote Originally Posted by esandes View Post
    Then what are you talking about?
    Discuss!
    Please go jeffrey Dr WeatherBoner's Avatar
    Shitcago
    48,447
    3534
    OP, stop pooping out of your mouth, it's not natural.
    28,297
    543
    Re-surfacing should only occur if the head is damage/warped or if you are attempting to increase compression.
    Bugzapper gonna zap 5.0THIS's Avatar
    39,879
    1016
    I have all of mine resurfaced at an angle so that some cylinders have more compression than others.
    Shitcago
    48,447
    3534
    Variable compression is becoming popular with professional drag car builders pushing 1000+ HP engines
    29,429
    12575
    Who ever tries to resurface a flat head? You always verify it's flat, but you don't have to cut it unless it's off. How is this a question?
    107,888
    I typically have mine resurfaced after every oil change
    Make it three yards... redy2kss's Avatar
    Northern Kentucky
    3,382
    Resurfacing the head also aids in those pesky 3,000 mile plug changes!
    39,879
    1016
    I also resurface my spark plugs when I do the heads.
    Shitcago
    48,447
    3534
    The part that goes in your butt or the other end?
    39,879
    1016
    Quote Originally Posted by Dr WeatherBoner View Post
    Both ends.
    No ragrets Tristan's Avatar
    In a van down by the river
    92,283
    1025
    Who resurfaces cylinder heads? I've got a stack of them in my storage unit. New pair with every oil change.
    #ItsMikeD Lucius Clay's Avatar
    Pensacola, FL
    59,022
    166
    I only run titanium heads so I'm not sure what the typical maintenance is on aluminum heads.
    107,888
    if you don't change out your transmission fluid every 3k miles you are a moran
    Oh I think they like me Tunavelli's Avatar
    Mar 2013
    Sussex, WI
    32,868
    8170
    With synthetic you can go for about 5k miles but you never want to exceed 3k RPM while running it since it might heat up too much and blow the manifolds.
    92,283
    1025
    Shitcago
    48,447
    3534
    Both ends.
    Pensacola, FL
    59,022
    166
    Quote Originally Posted by Tristan View Post
    I still remember my buddy's transmission in his late 90s F-150 taking a shit leaving the parking lot after seeing that movie
    Into the abyss EABiker's Avatar
    Frederick, MD
    10,605
    I always do my own, but you have to remember to just remove a little material at a time:
    29,429
    12575
    #FordLyfe
    89,304
    50
    I switched to carbon fiber heads.
    Northern Kentucky
    3,382
    OP must be off thinking of another subject to shitpost about.
    89,304
    50
    Quote Originally Posted by redy2kss View Post
    He is contacting Lunati to see about getting a 3/4 race cam position sensor for a 78 El Camino Red Line.
    the horror . . . the horror EVILFACE's Avatar
    Yukon, OK
    3,560
    446
    I installed cross drilled and slotted heads and haven't looked back.
    Frederick, MD
    10,605
    Quote Originally Posted by EVILFACE View Post
    Camel hump?
    Canada
    7,167
    746
    Quote Originally Posted by mogs01gt View Post
    Quote Originally Posted by 70Chevelle View Post
    Thanks guys.
