Results 1 to 3 of 3
Thread: 2005 GTO will not start looking for help pls
    Registered Member Gingerleah's Avatar
    Loranger, Louisiana
    534
    Hey everyone it's been awhile.
    I went to store to replace my GTO Battery just due to having to jump her after sitting and age of it. Well drove to several places then stopped at Auto Parts to get a battery. During the I saw a tiny spark during the removal of the old battery off the NEG wire. It bounced back and tapped the fender. ( I am not looking to blame just want car to run) The new battery was put in and now I have NOTHING during start. I have all lights, radio, windows but No start. I have power to the started relay inside the fuse box under hood you can feel a slight click. I have been told there is NO power getting to starter. Today we bought a new starter even though we were told the starter checked good. I see no point to replace a 12 yr old starter for the 4th time. Can anyone direct us pls? Thank you for your time and help.
    Apr 2010
    1
    Quote Originally Posted by Gingerleah View Post
    I'm having what may be the same problem. Did you have any codes when it would not start? What did you wind up doing to fix it?
    Apr 2019
    1
    Check your entire fuse box. Could have blown any of those with a stray ground. For instance, if it grounded to the fuel fuse you would get click but not start. Thats a shitty job. Did someone else install the battery for you?
    Sent from my VS501 using Tapatalk
