Page 1 of 5 12345 LastLast
Results 1 to 60 of 279
Thread: #lsswaptheworld
    Registered Member STANG KILLA SS's Avatar
    KILLEEN TX
    14,433
    Exclamation #lsswaptheworld
    KILLEEN TX
    14,433
    KILLEEN TX
    14,433
    174,697
    Quote Originally Posted by STANG KILLA SS View Post
    Is that an S10? I bet that thing is a blast.
    KILLEEN TX
    14,433
    Ferrari 360 GT powered by a supercharged Lingenfelter 1000hp 427 LS7
    KILLEEN TX
    14,433
    yes sir it is. quite a famous build.
    "What up 2-1-2" Locker537's Avatar
    MA
    15,372
    Gamertag: Locker537
    That twin turbo setup is beautiful to look at.
    107,936
    I love this thread
    13,272
    1283
    Friends neighbour put an LS1 I an early 90s 911. Biggest issue was the oil pan & rear suspension. I forget what pan he went with but it was lower profile than the stock f-body pan. Also had to make adjustments to the rear suspension because it'd squat so much under hard throttle that the oil pan would scrape the street
    174,697
    Quote Originally Posted by runningmole View Post
    Friends neighbour put an LS1 I an early 90s 911. Biggest issue was the oil pan & rear suspension. I forget what pan he went with but it was lower profile than the stock f-body pan. Also had to make adjustments to the rear suspension because it's squat do more under hard throttle that the oil pan would scrape the street
    IG: eightyfivesquared 70Chevelle's Avatar
    22,816
    4850
    Gamertag: Ls1Chevelle
    Put a LS1 in my Chevelle in ~03, it was being done but far from common.
    Waiting to find a decently priced combo to drop in my truck right now, the aftermarket for swaps and the knowledge that's available now is ridiculous.
    29,429
    12575
    Quote Originally Posted by 70Chevelle View Post
    I love that Holley now makes everything I need to do the swap on our Chevelle.
    LIFE IS GOOD HybridZ28's Avatar
    DFW, Texas
    29,000
    337
    Quote Originally Posted by Potent68 View Post
    By the time y'all get around to the swap, the LS motor will be an antique
    But seriously can't wait till see you guys finish her
    22,816
    4850
    It's nice, I had to cut and notch my oil pan myself and find someone to weld the aluminum cause custom pans didn't exist
    Lots of trial and error before I found which accessory setup would work. Had to get a bunt welded on my torque converter to make the th400 work.
    Had to use a painless wiring harness cause the info just wasn't out there to convert factory harnesses
    174,697
    What's odd is the swap for a Jeep, while keeping it a manual, is not cut and dry. IIRC, only 2, maybe 3 companies make conversion kits that'll allow the swap to work and I've heard headaches and complaints from folks that have used both/all. One brand/company is raved over while the other is cursed... and vice versa. From what I gathered, it's a crapshoot on whether the conversion will go smoothly or be a total PITA. If going auto, it's pretty easy and straight forward... but I don't want an automatic Jeep. On top of that, keeping the factory gauges working is another hurtle, as well. Sure, they make aftermarket gauges, but they don't match/look right in there at all.
    What the cluck? GldRush98's Avatar
    Springfield, IL.
    53,630
    5714
    Gamertag: GldRush98 Steam ID: GldRush98
    When LS is life
    174,697
    an LS swapped 300ZX is cool, IMO.
    Springfield, IL.
    53,630
    5714
    Can't believe I almost forgot to add a local one. Used to ride with this dude back in the day. LS Swapped Rambler.
    KILLEEN TX
    14,433
    174,697
    DFW, Texas
    29,000
    337
    Got a guy I know, he's pretty big around these parts, that loves LS motors and swaps. Here's a couple of his rides, I'm sure a few of y'all can recognize them
    KILLEEN TX
    14,433
    DFW, Texas
    29,000
    337
    Those little Luvs are awesome. Had a buddy in HS that had a blue 4x4.
    13,272
    1283
    On a serious note, many of those cars just became much more reliable
    Springfield, IL.
    53,630
    5714
    World's first reliable DeLorean for sure
    red truck :smug: JUSTINASS's Avatar
    17,188
    34
    17,188
    34
    17,188
    34
    17,188
    34
    29,429
    12575
    Quote Originally Posted by HybridZ28 View Post
    I got the body mount kit. Once I order the fuel/brake lines (best to do with the body lifted up) we'll start putting her back together. I'm waiting to order the engine/transmission until the chassis is ready and I have all of the parts I need so I am still under warranty in case something goes wonky.
    Registered Member thefritz1's Avatar
    CT
    9,287
    1025
    PSN ID: MDF812
    Is there a marketplace for ls-swapped cars? I'd love to buy one completed or partially completed as I don't have the time nor mechanical ability to handle a full swap myself but if I ever had some discretionary funds I'd love to buy one.
    Registered Member FirehawkNS's Avatar
    Charlotte
    31,783
    14525
    I have a buddy doing a current Porsche build with an LS1. I like to say it's an early 2000 model. I'd have to find it on FB.
    13,272
    1283
    Quote Originally Posted by FirehawkNS View Post
    I'd love to check that out if you find it
    Never Ends....
    PC PaiN's Avatar
    Waco, TX
    25,238
    5269
    Gamertag: PC PaiN
    Quote Originally Posted by GldRush98 View Post
    Other than he used the stock trans
    Bugzapper gonna zap 5.0THIS's Avatar
    39,971
    1166
    nope.
    DFW, Texas
    29,000
    337
    nope.
    DFW people
    Charlotte
    31,783
    14525
    I am not sure on the year, someone else might notice what it is. It's done as he has posted pictures with it at VIR, but he hasn't posted completed motor shots that I could find. I could ask for some. He has also built a 300Z with an LS1 that I think he sold before getting this one.
    Edit
    Sorry he wrote me back and said he wasn't done yet (I guess the VIR shot was with the stock motor). He posted the motor almost ready to go in. And I think it's actually an LS3.
    Registered Member Black96lt1's Avatar
    G'vlle,SC
    16,183
    2261
    Gamertag: Gameskin
    Quote Originally Posted by JUSTINASS View Post
    18,733
    29,429
    12575
    Quote Originally Posted by Black96lt1 View Post
    I hadn't considered body colored bumpers on ours.
    G'vlle,SC
    16,183
    2261
    Gamertag: Gameskin
    I wouldn't of thought I'd like it but that car pulls it off quite well.
    Florida
    19,977
    Edit
    Someone should let him know about the oil starvation issues on the ls3 if he plans on tracking it .
    Springfield, IL.
    53,630
    5714
    Quote Originally Posted by thefritz1 View Post
    There is a Facebook group called "500plus hp for sale". Might want to join that and keep an eye out. I see swapped stuff from time to time.
    KILLEEN TX
    14,433
    KILLEEN TX
    14,433
    KILLEEN TX
    14,433
    Please go jeffrey Dr WeatherBoner's Avatar
    Shitcago
    48,479
    3520
    Newfield NJ
    12,333
    990
    that's what I would take. I had a 75 280Z back in the 80's. I loved that car and wish I still had it. LS/M6 would be perfect in that. Forget the turbo though. It would have enough power for me stock.
    17,188
    34
    17,188
    34
  51. #51
    Registered Member TOPPED_OUT's Avatar
    Chicago
    9,293
    Best thread I've seen in a while.
    Even better than Blk's because this sex thread has pics
  52. #52
    Into the abyss EABiker's Avatar
    Frederick, MD
    10,616
    Quote Originally Posted by TOPPED_OUT View Post
    And I will take the smell of hot oil and burning rubber any day over, well, you know.
  53. #53
    Springfield, IL.
    53,630
    5714
    Quote Originally Posted by WeatherBoner View Post
    Holy fuck. I bet that one is fun to drive
    Ah who am I kidding... anything with an LS is fun to drive
  54. #54
    KILLEEN TX
    14,433
    550hp LS3
  55. #55
    Springfield, IL.
    53,630
    5714
    I bet this one rustles some jimmies
  56. #56
    KILLEEN TX
    14,433
    i want a LS 240 or RX7 pretty bad for road racing.
  57. #57
    18,733
    That thing is tits
    Love the wheel choice
  58. #58
    Shitcago
    48,479
    3520
  59. #59
    your mom savantard's Avatar
    Houston
    16,542
    72
    Gamertag: savantard
    Local one I've seen at a couple shows. The Metropolitan in this pic is definitely not LS powered lol
  60. #60
    22,816
    4850
    Those edelbrock coil covers are just awful
