Results 1 to 8 of 8
Thread: Pix of LS6 Intake and Part Numbers
    Just Another Doctor BoneSS's Avatar
    Ashland, KY
    1,481
    ?'s About My LS6 Intake--Rear and LPE Adaptor (Big Pics)
    Does the part that comes out the back, the part where the 2 vacuum hoses and MAP sensor hook up, come straight out, perfectly level horizontal, or project out at an angle downward somewhat? I bought locally a LS6 intake for $290, part number ends in 12561184 (01-02 F Car), flat bottom, w/ what looks to be the LPE EGR adaptor (what I was looking for). The rear has been resealed, and wanted to make sure it was done right. I am not sure if it was broken at some point, or if it sealed to be on the safe side. It doesn't leak when tested w/ water though. What do you all think? I can get my money back, but a SLP is 465 plus shipping, and just the LPE Adaptor for a LS6 intake is 150. I don't want to run around w/ a SES light, nor want to buy Edit/Tuner right now, so the EGR LS6 is my options. Thanks for any feedback!
    Also, does this look like the LPE piece installed? A sort of boot goes around the EGR metal plate and it slides down into the intake.
    Thanks!!!
    42,543
    vaccuum doesn't have a problem turning corners so if the rear fitting is leak-free, and everything physically fits back there, you're good.
    Not sure on your EGR query.
    User title makes good sense right now, eh?
    FML jrp's Avatar
    Santa Clarita, Ca
    4,197
    10750
    PSN ID: j_r_p
    replied on 'tech.
    Ashland, KY
    1,481
    Thanks guys! Sorry for the size of the pics. I did have them bigger, and resized--honestly
    Registered Newbie Constrictor's Avatar
    Chicago Heights, IL
    9,038
    It looks fine to me. The only thing I would be worried about is the quality of the sealing. Are you sure thats even an LS6 intake? Is the bottom flat?
    Registered Member VA2001SS's Avatar
    Warrenton, Virginia
    121
    I show the 01-02 LS6 intake as #12561182 at least that is what is on my 01.
    Ashland, KY
    1,481
    Yes, the bottom is flat.
    I ran a search over at Tech, and found this quote by DALEMX:
    The Stock 2001-2002 F-body LS6 is 12561184.
    The Z06 LS6 is 12573572.
    These are the numbers stamped on the manifold
    I believe that the F-body manifold is prefered and flows a little better than the Z06.
    The old LS1 intake with the EGR setup is 12560688.
    I filled the thing w/ water, and have used air also, to attempt to find leaks, and it seems to be air/water tight. Any other ideas on how to check? Will any of this hurt performance you think? When I look inside w/ a flashlight, it looks perfect, no adhesive or anything that I can see.
    Chicago Heights, IL
    9,038
    There are some good pics and info on part numbers here. I'm going to archive this in the Help section.
