Thread: write up for plug in fan mod.
    1998 Ws6 M6 #370
    orlando
    429
    Here is the write up for a plug in fan mod, no splicing. I made it a long time ago, for the site.
    hope this helps the +1 site
    First here is the parts you need.
    9 male, and 9 female connectors, 18 cable seals, 2 empty plugs, 1 male 10 pin connector, and 1 female 10 pin connector, and 2 strain reliefs, and 1 retainer clip to hold the terminals together.
    Then you need to cut 9 wires, about 7" long.
    After you cut the wires, slide on the cable seals, and strip about 1/4 inch off each end.
    then after stripping each end, Pick 7 of the wires, and pull the other 2 aside.
    Start with one set of terminals, (male or female) and crimp them into place (note, requires special tool) if you don't have the special tool, needle nose pliers, and a soldering gun should work
    Continue and do the other side, and you will end up with this.
    After securing the cable seals, with the other special tool (or a pair of standard crimpers should work, if your careful) go back to the 2 you left out before.
    I use one blue for the high speed, and a normal black for the low. If i had green, i would use that for low. to match the factory colors.
    Strip back about 1/2" of insulation in the middle of your blue wire, and connect another piece of wire to go into the vehicle. Solder this connection. Should look like this.
    Repeat for the low speed setting.
    When your done, slide heatshrink over the connections should look like this.
    Then heat the connections.
    (note: paper is just there for the pics, use common sense)
    Once your done with those 2 wires, your ready to assemble.
    Start out by cutting a piece of large 1" or so heat shrink to hold all the wires in place.
    Attach the blue wire into pin H
    and the black wire, with the splice into pin J
    Continue to add 1 wire at a time, and match the letters on the end, your going to leave pin F empty.
    Once you have installed the 9 wires, install the empty seal as shown.
    Before going to the next step, take a meter, and verify that the pins are A to A, B to B, and C to C ... all the way to K
    After installing the 9 wires, and the cable seals, line up the strain relief.
    Clip the strain relief into place, and repeat the other side.
    Heat the heatshrink tubing, and your done with the under hood portion.
    This should take about an hour.
    It works as follows.
    You ground the Blue and Black wire, to actvate the high speed fan.
    Ground just the black wire to activate the low speed settings.
    You can use any of the other methods on the internet, to prevent ses lights, ect.
    I like this method, for easy to obtain parts. http://makoto.dyndns.org/fan_switch.html
    just use 2 watt 47 ohm resitors, instead of the 1 watt.
    if you want information on how to get these parts, they are not a sponsor, e-mail me for that info Ryan212@aol.com put fan mod or fan parts in the title.
    Ryan
    262 77
    Guest
    slow, excellent write up.
    I'm going to copy it into "How to, Methods & Procedures" Forum.
    102,201
    6413
    May I download the pictures to our server? I'll change the links to point here and then you don't have to worry about red Xs showing up if you move the pictures or the host site changes.
    1998 Ws6 M6 #370
    orlando
    429
    yes PLEASE host the pics here
    Ryan.
    102,201
    6413
    Links changed and hosted on this server. Make the copy.
