Page generated in 0.11773 seconds with 18 queries [Server Loads: 0.40, 0.30, 0.32]
03-07-2008, 04:47 AM
Leaving, on a Jet Plane
Nitrous Help!!!
Is the MSD Digital Window Switch programmable? Meaning, can I, myself, program what gears to spray in, and within a specific RPM range? Or does it come pre-programmed. This is an a4 LS1 btw. Thanks.
03-07-2008, 06:28 PM
If it is the same one I have then no. You can specify the rpm 'window' to what ever you like but it does not have a gear lockout or specific gear windows. If you want that level of customization, you will have to step up to a higher end model.
2000 Silverado, RCSB, 2wd
WRE 370 / Kenne Bell 2.8L / 4L80E
11.21 @ 121
2001 Tahoe LT 4wd
Bolt-on daily driver and tow vehicle.
