Go Back   LS2 Forums > LS1, LS2, LS3, LS6, LS7, LS9 | F-Body, GTO, C5, C6, CTS-V LS2.com > Nitrous
mjm autohaus  Edelbrock Performance Suspension  LS2.com Store
Page generated in 0.12944 seconds with 23 queries [Server Loads: 1.81, 1.89, 1.69]
Old 03-09-2007, 02:41 AM   #1
iwantazorta
iwantazorta's Avatar
any lt1 8.00 or below 1/8th mile out there
Do we have any bolt on lt1s with spray hitting sub 8.00 runs in the 1/8 on this site? What shot? What mods. What 60'.
- Mike
iwantazorta is offline   Reply With Quote
Old 04-05-2007, 08:41 PM   #2
440cidLS7
Your Drywall Man!
That may be a tall order.
2000 SS Camaro M6 Red-440cid LS7 Forged Callies crank(4.125 Stroke),Forged Rods, Forged Manley Pistons,Comp Custom Ground Cam(244/258-612/580 @115LSA)Hellfire Rings,CNC'd L92 Heads, Kooks 1 7/8 Long Tubes, Custom Built true duals, 90/90 Intake and TB, McLeod Street Twin, 9 inch w/ 4.30's, MSD 60lb injectors, MSD in-line, Racetronix in-tank, PA racing torque arm & STB, BMR LCA's & Rear Sway Bar, QA1's on all 4 corners
2005 K3500 D-Max Dually / 430rwhp-837rwtq-GONE!
2009 Z-71 4x4 6inch Procomp stage 2 lift, 35x12.50x20 Extreme AT's
440cidLS7 is offline   Reply With Quote
Old 04-29-2007, 08:47 AM   #3
SSConceptz
98Z28 6.0L 214-686-9375
SSConceptz's Avatar
Send a message via AIM to SSConceptz Send a message via Yahoo to SSConceptz
Not a tall order, there are plenty, I am running under 8s in the 1/8 mile but on motor + slicks. Adding 100 shot too, hoping for some 6s.
SSConceptz is offline   Reply With Quote
Old 04-30-2007, 06:22 PM   #4
440cidLS7
Your Drywall Man!
Re: any lt1 8.00 or below 1/8th mile out there
- Mike
Ok.................Mike but you arent running a stock configured LT1 with 390+cid.
Old 05-02-2007, 03:25 AM   #5
jmill96Z
LSWHAT????
jmill96Z's Avatar
355, Hotcam, untouched LT4 heads, 150 shot and suspension 7.10@98
jmill96Z is offline   Reply With Quote
Old 06-30-2007, 02:10 AM   #6
Chopstix
Send a message via AIM to Chopstix
7.4's NA
6.6's on a 150 shot
soon to be much faster
Chopstix is offline   Reply With Quote
Old 06-30-2007, 06:19 AM   #7
440cidLS7
Your Drywall Man!
What ignition are you using? And are you still using the factory "hyperucractic pistons"? The reason i ask about the ignition is, i had a 95 LT1 car and it would only burn about a 75 shot on the factory ignition.
NFL Gear 4 Less
Fuelie Guitar Pickups
General Motors Western Region Communications Team
Brown Line Metalworks, LLC
Site Owner: Eric Boggs -- Copyright © 2004 - 2013, WWW.LS2.COM
