Go Back   LS2 Forums > LS1, LS2, LS3, LS6, LS7, LS9 | F-Body, GTO, C5, C6, CTS-V LS2.com > Nitrous
GM Inside News  COMP Cams  NFL Gear 4 Less
Page generated in 0.33465 seconds with 26 queries [Server Loads: 0.72, 1.85, 2.34]
Old 09-14-2006, 01:24 AM   #1
Z28er
Is it my clutch,petal assembly,or both that is sticking under WOT on NX wet 150 shot?
I have a ZO6 clutch now on my '99 Camaro 6spd with 4.10 gears, but still, from a dead stop at WOT, my clutch sticks after the NX wet 150 kicks on and shifting to the next gear and stomping on the throttle again just leaves the clutch partially stuck in forever....burning it up and not allowing the full power to the ground.
Is it my clutch?
Is it my petal assembly?
Is it my 4.10 gears?
Is it all of the above?
Anything I can do besides comments telling me to change clutches?
If I do a roll out it is fine....just when I use it from a dead stop is when I have this prob? I remember reading some sort of GM recall or problem with petal assemblies as well?
Thanks,
Rich
Z28er is offline   Reply With Quote
Old 09-14-2006, 09:23 PM   #2
Harris Speed Works
Harris Speed Works's Avatar
Have you tried doing the drill mod to the master yet? Install University has a write up on it if you haven’t. More then likely your clutch is on it's way out too.
Matt
Harris Speed Works Website
Email Tech & Sales Questions
Sales & Tech Line
215-674-5909
Harris Speed Works is offline   Reply With Quote
Old 09-15-2006, 03:21 AM   #3
Z28er
I have the drill mod and the updated hydraulics....did it when they installed the ZO6 clutch and flywheel. I even got and upgraded pilot bearing, and it still does it. The clutch is fine w/o the NX, but once I hit it out of 1st from a dead stop, it can't handle the power or something? It feels like it is sticking in a little instead of all the way out?
I am having my local GM dealer bleed my haydraulics and look for leaks to see if this is the problem.
Thanks for the info,
Rich
Old 09-21-2006, 12:53 AM   #4
edzsilverss
The Z06 clutch is not alot better than the stock one you had in there..Your throwing rocks at a glass house...Put a Spec III or better in there....
99 SS Mac mids, 2.5 true duals, lid, free ram air, Sunami cam, AFR 205 heads, Patriot gold dual springs, ls6 oil pump, ls6 intake, spec III clutch, msd wires, tr6 plugs, 125 dry shot. S2. ASP U/D pulley. 4.10 gm gears. SQR tune
edzsilverss is offline   Reply With Quote
Old 09-22-2006, 07:59 PM   #5
nevrlift
always ready...
nevrlift's Avatar
Send a message via Yahoo to nevrlift
i have a 2001 t/a and it does the same thing...w/o drill mod...i'm running a 100 shot and when i race i spray in 1st also....my pedal will stick and sometimes i cant even get into 3rd....we both need a better clutch set up.....
nevrlift is offline   Reply With Quote
Old 09-22-2006, 10:37 PM   #6
Z28er
Maybe, but I was going to do the SPEC III at the time...it just seemed there were to many probs...people would complain all the time about crazy chatter noise, etc.
Is the SPEC III really our prob?
Rich
Old 09-23-2006, 01:17 AM   #7
edzsilverss
Rich
The chatter is not bad at all. Only the first 500 miles or so...My spec III has held several 5000 rpm drops and held just fine on the hose. If you know how to drive, chatter is not an issue. You can't pussyfoot around with it..Drop that bitch and go..There is no feathering any good aftermarket clutch...
Old 09-23-2006, 01:35 AM   #8
Z28er
Nice comments, that made me laugh...For the first time, I saw the bleed method on the drivetrain section by Ramos...this sounds exactly like my prob...last two inches are not coming out on the clutch...I will try this first and report back in a few, otherwise, I guess some day I will have to pony-up on a SPEC III.
Rich
Old 10-10-2006, 05:16 AM   #9
5letr
2006 GTO
Get a better clutch. A spec II or III would do fine.
5letr is offline   Reply With Quote
Old 05-17-2007, 03:42 AM   #10
nevrlift
always ready...
nevrlift's Avatar
i agree...wish i could afford a textrilla or spec
Brown Line Metalworks, LLC
General Motors Western Region Communications Team
Fuelie Guitar Pickups
mjm autohaus
Site Owner: Eric Boggs -- Copyright © 2004 - 2013, WWW.LS2.COM
