Go Back   LS2 Forums > LS1, LS2, LS3, LS6, LS7, LS9 | F-Body, GTO, C5, C6, CTS-V LS2.com > Nitrous
COMP Cams  EFI Live  mjm autohaus
Page generated in 0.24184 seconds with 19 queries [Server Loads: 0.56, 0.53, 0.54]
Old 02-20-2006, 09:05 PM   #1
Harris Speed Works
Harris Speed Works's Avatar
Spark Plug Reference Chart
Hey guys, been working on this for a little while and finally have it ready to post. Maybe someone can sticky it to the top so that people can easily reference it? It's fairly hard to compare each manufacturers heat range since there are so many factors involved but this is, in my opinion, the closest match for NGK's heat range system, which was used in the chart. If you guys would like to see certain plug manufacturers added, let me know.
Spark Plug Info
**Note: Heat ranges are determined by NGK standards. Not all plug manufacturers follow the same guidelines.
***Note: List is intended for reference only. Please consult with head mfg. and ignition mfg. for proper gap.
****Note: NGK IX and Denso plugs are Iridium.
LT1
Thread – 14mm
Reach - .708”
Socket – 5/8 hex
Seat - Taper
Stock Heat Range: 5
Gap: .050
Plug: NGK TR55 (stock number 3951); NGK TR55IX (stock number 7164); Autolite 764; Champion RS14YC6 (stock number 13); Denso IT-16 (stock number 5325)
Nitrous (one step colder)
Heat range: 6
Gap: .035 - .038
Plug: NGK TR6 (stock number 4177); NGK TR6IX (stock number 3689); Autolite 103; Denso IT-20 (stock number 5326)
Nitrous (two steps colder)
Heat Range: 7
Gap: Consult
Plug: NGK BR7EF (stock number 3346); NGK TR7IX (stock number 3690); Autolite AR94; Denso IT22 (stock number 5327)
LT1 w/ AFR heads
Thread – 14mm
Reach – 3/4”
Socket – 5/8 hex
Seat – Gasket
Stock – MFG Recommendations
Heat Range: 9
Gap: Consult ignition mfg.
Plug: NGK 5672A-9 (stock number 7405); Autolite AR3910; Champion C59YC (stock number 792); Denso IQ27 (stock number 5315); Denso IQ01-27 (stock number 5708)(diagonal platinum ground); Denso IQ02-27 (stock number 5711)(horizontal platinum ground)
Heat Range: 10
Plug: NGK 5672A-10 (stock number 7942); Autolite AR50; Denso IQ31 (stock number 5323)
Heat Range: 11
Plug: Denso IQ34 (stock number 5324)
LT1 w/ Trick Flow & Edelbrock Heads
Thread – 14mm
Reach – 3/4”
Socket – 5/8 hex
Seat – Gasket
Stock – MFG Recommendations: approx under 9:1 compression
Heat Range: 4
Plug: NGK FR4 (stock number 5155); NGK BKR5EIX (stock number 6341); Autolite 3926; Champion RC12YC (stock number 71); Denso IK16 (stock number 5303)
MFG Recommendations: approx 10.5:1 compression
Heat Range: 5
Plug: NGK FR5 (stock number 7373); Autolite AR3924 (Racing Plug); Autolite 3924; Champion RC9YC (stock number 2075); Denso K20PR-U (stock number 3145); Denso IK20 (stock number 5304)
MFG Recommendations: approx 11:1 compression
Heat Range: 8
Plug: NGK R5672A-8 (stock number 7173); Autolite AR3911; Champion C63YC (stock number 796); Denso IQ24 (stock number 5314)
MFG Recommendations: approx 12:1 compression
Heat Range: 9
Plug: NGK R5672A-9 (stock number 7405); Autolite AR3910; Champion C61YC (stock number 785); Denso IQ27 (stock number 5315)
MFG Recommendations: approx 13:1 compression
Heat Range: 9 - 10
Plug: NGK R5671A-9 (stock number 5238); Autolite AR3933; Champion C59CX (stock number 296); Denso IK27 (stock number 5312)
MFG Recommendations: approx 14:1 compression
Heat Range: 10
Plug: NGK R5671A-10 (stock number 5820); Autolite AR3932; Champion C57CX (stock number 295); Denso IK-31 (stock number 5321)
**NOTE: Use chart for static compression and adjust heat range for nitrous use accordingly.
LS1 Stock and AFR
Thread – 14mm
Reach - .708”
Socket – 5/8 hex
Seat - Taper
Stock Heat Range: 5
Gap: .060
Plug: NGK TR55 (stock number 3951); NGK TR55IX (stock number 7164); Autolite 764; Denso IT-16 (stock number 5325)
Heat Range: 6
Gap: .035 - .038
Heat Range: 7
Gap: Consult
Nitrous (two and a half steps colder)
Heat Range: 8
Gap: Consult
Plug: NGK R5724-8 (stock number 7317); NGK TR8IX (part number 3691); Denso IT-24 (stock number 5328)
Nitrous (three steps colder)
Heat Range: 9
Gap: Consult
Plug: NGK R5724-9 (stock number 7891); Autolite AR93; Denso IT-27
Nitrous (four steps colder)
Heat Range: 10
Gap: Consult
Plug: NGK R5724-10 (stock number 7993); Autolite AR92
LS1 w/ Edelbrock and Dart Heads
Thread – 14mm
Reach – 3/4”
Socket – 5/8 hex
Seat – Gasket
Heat Range: 4
Heat Range: 5
Heat Range: 8
Heat Range: 9
Heat Range: 9 - 10
Heat Range: 10
4.6 Mustang GT
Thread – 14mm
Reach - .708”
Socket – 5/8 hex
Seat - Taper
Stock Heat Range: 5
Gap: .054
Plug: NGK TR55 (stock number 3951); NGK TR55IX (stock number 7164); Motorcraft AWSF-32C (copper); Autolite 764; Denso IT-16 (stock number 5325)
Heat Range: 6
Gap: .035 - .038
Plug: NGK TR6 (stock number 4177); NGK TR6IX (stock number 3689); Motorcraft AWSF-22C (copper); Autolite 103; Denso IT-20 (stock number 5326)
Heat Range: 7
Gap: Consult
Plug: NGK BR7EF (stock number 3346); NGK TR7IX (stock number 3690); Motorcraft AWSFA-12C (copper); Autolite AR94; Denso IT-22 (stock number 5327)
Heat Range: 8
Gap: Consult
Heat Range: 9
Gap: Consult
Heat Range: 10
Gap: Consult
4.6 Mustang Cobra (96-01)
Thread – 14mm
Reach - .708”
Socket – 5/8 hex
Seat - Taper
Stock Heat Range: 5
Gap: .054
Heat Range: 6
Gap: .035 - .038
Heat Range: 7
Gap: Consult
Plug: NGK BR7EF (stock number 3346); NGK TR7IX (stock number 3690); Motorcraft AWSFA-12C (copper); Autolite AR94; Denso IT22 (stock number 5327)
Heat Range: 8
Gap: Consult
Heat Range: 9
Gap: Consult
Heat Range: 10
Gap: Consult
4.6 Mustang Cobra (03-04)
Thread – 14mm
Reach - .708”
Socket – 5/8 hex
Seat - Taper
Stock Heat Range: 6
Gap: .049 - .052 (have had better results with tighter gap)
Heat Range: 7
Gap: .035 - .038
Heat Range: 8
Gap: Consult
Plug: NGK R5724-8 (stock number 7317); NGK TR8IX (stock number 3691); Denso IT-24 (stock number 5328)
Harris Speed Works Website
Email Tech & Sales Questions
Sales & Tech Line
215-674-5909
Harris Speed Works is offline   Reply With Quote
Old 02-20-2006, 09:05 PM   #2
Harris Speed Works
5.0 Mustang 87-95
Thread – 14mm
Reach - .460”
Socket – 5/8 hex
Seat – Taper
Stock Heat Range: 4
Gap: .054
Plug: NGK UR45 (stock number 6945); NGK UR45IX (stock number 3207)
Heat Range: 5
Gap: .035 - .038
Plug: NGK UR5 (stock number 2771); NGK UR5IX (stock number 7177)
Heat Range: 6
Gap: Consult
Plug: NGK UR6 (stock number 7773); NGK UR6IX (stock number 7348)
5.0 Mustang Cobra 93-95 w/ GT-40 Heads
Thread – 14mm
Reach - .708”
Socket – 5/8 hex
Seat - Taper
Stock Heat Range: 5
Gap: .054
Plug: NGK TR55 (stock number 3951); NGK TR55IX (stock number 7164); Autolite 764 or 104; Denso IT-16 (stock number 5325)
Heat Range: 6
Gap: .035 - .038
Heat Range: 7
Gap: Consult
Heat Range: 8
Gap: Consult
Ford F-150 Lightning (99-04)
Thread – 14mm
Reach - .708”
Socket – 5/8 hex
Seat - Taper
Stock Heat Range: 6
Gap: .049 - .052
Heat Range: 7
Gap: .035 - .038
Heat Range: 8
Gap: .033 - .036
Heat Range: 9
Gap: Consult
Plug: NGK R5724-9 (stock number 7891); Autolite AR93; Denso IT-27 (stock number 5329)
Sales & Tech Line
215-674-5909
Old 02-20-2006, 09:29 PM   #3
XTrooper
LS2.Com Moderator
XTrooper's Avatar
Send a message via ICQ to XTrooper
Nice work, Matt!
Steve - NJ State Trooper #3936 (retired)
Life Member: VFW & Vietnam Vets of America
2000 Millennium Yellow Corvette Convertible
Mods: Hurricane intake, Halltech Cobra air bridge, LS6 intake manifold, XTrooper Cam (223/227 .566/.567 112), Rapid Motorsports Stage II LS1 heads, Crane 1.80 Quick-Lift rockers & dual valve springs, ATI Super Damper, Rollmaster double roller timing chain, TTS headers, MagnaFlow exhaust/x-pipe, QTEC electric cutouts, NX/Nitrous Outlet wet kit, Yank SY3500, 3.73 gears, Baer EradiSpeed rotors, Z06 chrome wheels, Nitto drag radials
441 rwhp/418 rwtq
11.478@121.55 60'=1.696
XTrooper is offline   Reply With Quote
NFL Gear 4 Less
Fuelie Guitar Pickups
General Motors Western Region Communications Team
Brown Line Metalworks, LLC
Site Owner: Eric Boggs -- Copyright © 2004 - 2013, WWW.LS2.COM
