06-08-2006, 05:15 PM
Technical Data for LS2, 2005 & 2007
06-08-2006, 05:35 PM
06-08-2006, 05:39 PM
06-08-2006, 05:45 PM
06-08-2006, 05:46 PM
06-08-2006, 05:56 PM
06-08-2006, 11:56 PM
Engine Controls Component Views
Engine Component Views 2, Sensor Locations
Engine Sensor Locations 2
2006 ECM Vette
2007 ECM Vette E38_01
2007 ECM Vette E38_02
2007 ECM Vette E38_03
2007 ECM Vette E38_04
2007 ECM Vette E38_05
2007 ECM Vette E38_06
2007 Data Link Connector
Engine Oxygen sensors Locations
Throttle Position Assembly
ECM, MAF & A/C Pressure Sensor
ECM Connector C1
ECM Connector C2
ECM Connector C2, C3
A/C Refrig Pressure Sensor, CMP Sensor, Accelerator Pedal Sensor, Clutch Pedal Position Sensor C1
Clutch Pedal Position Sensor C2, CKP Sensor, DLC Connector, ECT Sensor
Engine Oil Pressure, EVAP Purge, EVAP Vent, Fuel inj 1
Fuel inj 2 - 5
Fuel inj 6 - 8, Fuel Pump and Sender
Fuel tank pressure, O2 B1S1, O2 B1S2, O2 B2S1
O2 B2S2, Ignition Coil 1 - 3
Ignition Coil 4 - 7
Ignition Coil 8, Knock Sensor 1 & 2 MAP Sensor
MAF, Park/Neutral Switch
Power Interface Module, Reverse Lockout Solenoid, Skip Shift Coil Assembly
Throttle Actuator Control, VSS, Scan Tool Normal Ranges 1
Scan Tool Normal Ranges 2
Scan Tool Normal Ranges 3
Scan Tool Normal Ranges 4
Scan Tool Normal Ranges 5
06-12-2006, 06:06 PM
04-27-2007, 04:37 AM
#9
Junior Member
dash cluter wiring
got any pinouts for the dash cluster? wiring codes etc? want to wire in a dash
05-27-2007, 09:10 PM
#10
Senior Member
Got any for the TBSS version?
05-28-2007, 02:00 PM
#11
I have the Helms on the LS2 for the GTO. I also have the Helms for the 07 Vette also with the LS2. Exactly what information do you need?
Elmer
11-21-2007, 02:15 AM
#12
Registered User
Thanks E.
I just aquired a 2005 Cyclone Grey GTO M6 4929 on the clock.
traded in the GMC. This info will be helpful.
Paul Mc
12-12-2007, 03:38 PM
#13
Designed For Action
The pictures that you posted up: what vehicle were those for. I have a 2006 GTO so I wondered if that was the right one.
01-07-2008, 04:41 PM
#14
The darkest burning Star
Damnit EB you couldn't make a PDF or something
01-09-2008, 09:29 PM
#15
Junior Member
Can anyone identify what year this is for? E38 or E40 PCM?
01-10-2008, 01:46 AM
#16
Marsupial
2005 Pontiac GTO and probably all still good for a 2006 Pontiac GTO.
E40.......based on the Cam Gear shown here
----> Engine Components Front
Also because there are 3 ECM connectors shown here ---->
ECM Connector C1
ECM Connector C2
E40 (3 connectors)
E38 (2 connectors)
Aussie Dum Mutant
01-23-2008, 02:04 PM
#17
Junior Member
Great information here. Do you have an illustation of the Vette front accessories? Particularly the power steering pump/ reservoir.
I'm trying to determine if another model pump will work with the Vette alt/ps pump bracket -- or am I stuck with having to buy the $250 model specific unit.
02-19-2008, 07:04 AM
#18
Junior Member
ECM Connector C1
ECM Connector C2
E40 (3 connectors)
E38 (2 connectors)
Any chance you have the e38 info ?
02-19-2008, 07:20 AM
#19
Marsupial
Maybeeee.....what you chasing Digger ?
Pinouts ??
02-19-2008, 02:15 PM
#20
Junior Member
Pinouts ??
Pinouts please  a new guy is undertaking a L76 conversion into '85 Pontiac Firebird.
Cheers
02-20-2008, 01:00 AM
#21
Marsupial
Cheers
I thought I had pinouts for an E38 but I don't.
I do have E40 pinouts.
I've only got a wiring harness instruction sheet for an LS7, 58x reluctor, Manual trans,...with a 2 terminal PCM but I can't be 100% positive it's an E38.
I've got a dimensioned drawing of an LS7 PCM #12603892...again I do not know 100% if this is E38.
Best bet contact Elmer above....he says he has Helms manual for 2007 Vette.
Aussie Dum Mutant
02-21-2008, 09:06 PM
#22
I just loaded the 2007 Vette E38 Pin Outs
02-22-2008, 11:22 AM
#23
Junior Member
 eboggs_jkvl Thanks.
Also thanks to HSV-GTS-300
08-19-2008, 03:09 PM
#24
A6 6L80E wiring 1 of 2
08-19-2008, 03:10 PM
#25
A6 6L80E wiring 2 of 2
08-19-2008, 03:45 PM
#26
Junior Member
Great info!
I'm doing a litle reserch to find a way of using an aftermarket programmable injection and still use the 6l80e trans.
Does the manual include any system descriptions of the TCM and ECM? I would really appreciate more info of thoose systems.
It would maby be possible to make a custom harness for the e38 to control only the transmission.... hmm...
Thanks,
Simon
08-19-2008, 05:03 PM
#27
I'm digging on my DVD. Does this help in any way?
DTC P1825 or P1915
08-19-2008, 09:47 PM
#28
Junior Member
DTC P1825 or P1915
It helped me to understand the funktion of the DTC logics, thats also a step forward.
I'm greatful for all the info. It's impossible to find such info in Swedish forums..
08-20-2008, 03:24 PM
#29
Chassis measurements are not in Helms as I thought they were. There must be another book used by repair shops to work on frames and realignment, sorry.
I did add all of the A6 connectors that I saw in the book. I have them listed in post #8
08-20-2008, 04:35 PM
#30
Marsupial
Originally posted by marmander
Great info!
Thanks,
Simon
Simon,
Have a read of this whole thread. You'll find some answers and contacts for people working on custom solutions.
http://www.performancetrucks.net/for...d.php?t=401899
08-20-2008, 10:29 PM
#31
Junior Member
thanks once a again "eboggs_jvkl", I think I have all the info I will need to make my own custom harness know.
I don't think i will use aftermarket EMS afterall, I still need HP tuners or EFI live to tune the trans etc.
An alternative would be to use the sensors for both the E38 and my aftermarket injection and not connect ignition coils and injectors to the E38. Then use the aftermarket programmable injection for fuel and ignition.
"HSV-GTE-300", I will read the thread thoroughly (spelling?) and se if I get a better owerview
I'll let U guys know when my project starts for real, right know I'm buildning my own work shop.
Simon
08-25-2008, 03:43 PM
#32
Junior Member
Hi I have fitted a LS2 in a Ultima GTR using a E40 is it posible to at cruise contol? if so how or any info,pointers would be usefull regards Simon
08-25-2008, 04:25 PM
#33
Marsupial
Yes it's possible to get cruise control working.
What throttle body do you have ?
Do you have the cruise control module, switches on the clutch (if applicable) and brake pedal, cruise control activation stalk mounted to steering column, VSS (vehicle speed sensor) working ?
08-25-2008, 05:07 PM
#34
Junior Member
I have 90mm electronic throttle can add switches for clutch and brake, speed sensor is fitted and working, want to mak my own stalk if posible most use 2 wires and different resistor values for each function. I do not have the cruise control module what part number is it and do you have any wiring diagrams.
08-25-2008, 09:35 PM
#35
Marsupial
This is all I have that might be of any use.
It looks to me as if there is no need for a seperate Cruise Control Module when using this computer.
Main Computer…………………Service #12200411
There's info there that will help with the stalk.
http://www.hsv-gts.ls2.com/90543Manual.pdf
1.4Mb
pdf format
