04-28-2005, 04:20 PM
Member
DON'T LOSE YOUR T-TOPS (See HERE)
Good Morning all!
I am posting here as information only. Please, no flames as I am just trying to help someone out that may potentially have an issue down the line.
On Sunday (past), I was lucky enough to be a new member of the "Oh Crap, my T-top Just blew off!" club. I haven't been a happy camper since. I was lucky enough to have found someone local (Thank you SFFBA) that had 2 for sale.
Now, let me lay the facts out before you start reading on. My T-top was latched, no question. It was locked also, so I know 100% that it was latched at the time. I had the windows down and was cruising at about 75 when I started hearing a bad wind noise (just like someone was passing me), then, a split second later, off went my Drivers side T-top. Talk about  . Yesterday I picked up a new (to me) t-top and installed it without an issue, but took it one step further.
I looked at the adjusting pin receiver on the rear of the opening. You have to remove a small trim piece to be able to see it. It appeared that only a 1/8 of an inch was making contact and the slide bracket was ALL the way back. This was not good! Checked the passanger side and it wasn't as bad, but still could use some adjusting. What seems to happen is when you go to install your t-top and TRY to latch it, if it isn't PERFECT, it will slightly push that bracket back if you put too much pressure on it. I was able to bring the drivers side bracket snug by adjusting it a 1/4 inch or more. Much better fit. The passagerside was adjust another 1/8 inch for more contact and I am feeling much better.
BTW, locking your T-tops will not garrantee they stay on, it WILL, though, garrantee that your locking pins will stay in place and after looking at how the mechanism works, I would recommend to ANYONE to keep the tops locked at all times. Ounce of protection.
WORD TO THE WISE: PLEASE CHECK YOUR T-TOPS. It will take ten minutes of work, but will save you 100+ bucks in the future!
Good Luck,
Jonathan Hays
04-28-2005, 04:48 PM
Retired race car
I'm going to check mine when I get home, cuz im apart of that club also! and I could have sworn i latched mine down too!!
04-28-2005, 05:34 PM
Senior Monster
Hey there good post  can you post up some pics to go with it , this info would be very good for the newbies with T-tops. I would do it but my camera is dead
04-28-2005, 05:52 PM
I thought this was a great post. So I did some adjustments and pictures.
First, Take off the T-top
Next, remove the 2 phillips head screws that hold the trim cover in place and remove cover.
Next, take a 10mm box end wrench and loosen the 2 bolts holding the clamp. Do NOT remove the bolts.
Now, put your T-Top back on, latch it and then slide the bracket adjustment as far as you can toward the rear of the car. The bracket will slide on the T-Top mounting rod. I simply used a small screwdriver to do it.
Then simply tighten up the 2 10mm bolts to secure the latch receiver in place, take off the T-Top and replace the trim moulding.
I must admit, one was good but the driver side was barely doing it's thing. I feel a lot better now that the tops are secured.
Good call on this. It should save a lot of flying T-Tops.
NOTE::: If you are working on the front bracket, the slide with be moved to the rear of the car. If you are working on the rear bracket, the slide will move toward the front of the car. Get as much rod into the bracket as you can without making it too tight to easily insert the window and latch the lock. This note was added to clarify the direction that you move the bracket.
2007 Corvette Convertible, Victory Red, MZ6, Z51, B&B Route 66 Catback, E-Force Super Charger
04-28-2005, 06:57 PM
Member
Thanks E! Looks great!
04-28-2005, 07:54 PM
That's "Foreskins" to you
Mod war...Mod War!!
I always thought mine looked a little far back when looking down the crack at the t-top. Plan to check mine today!! Don't want to be apart of that club, that's for sure!!
1999 Pewter Z28
Flickr
1999 Z28, 2004 Acura RSX, 2001 Blazer LT
04-28-2005, 10:20 PM
Senior Member
I'm a member of the club. A month after i got my Z28 it happened but i was a newb so i dunno how it happend all i know is my friend was behind me and he said it went pretty damn high and then came down and shattered. I still catch shit for that 2 years later.
04-28-2005, 10:35 PM
PR7ME T7ME!
Re: DON'T LOSE YOUR T-TOPS (See HERE)
Originally posted by Twister
Good Morning all!
WORD TO THE WISE: PLEASE CHECK YOU T-TOPS. It will take ten minutes of work, but will same you 100+ bucks in the future!
Good Luck,
Jonathan Hays
Thanks for the info!
04-28-2005, 10:36 PM
#9
PR7ME T7ME!
04-28-2005, 11:08 PM
#10
RCFB Member
Check'em even if you rarely take them off - my driver's side was barely holding - been off the car maybe 4 times since I bought it new.
04-29-2005, 12:08 AM
#11
XBL - AlteredLS1
Just got through checking mine. I usually take mine off 5-10 times a year and all of them looked ok. All had about half inch of the bar catching.
04-29-2005, 12:14 AM
#12
Senior Member
thanks-will check--mine are off may to october all day,almost every day--also had them off all day yesterday-definately don't wanna lose one..
ALL BOLT-ONS.... LOW...At least 30 Aftermarket Goodies.....
04-29-2005, 02:35 AM
#13
Registered User
you can also adjust the front mounting tap too, takes a little bit more work, and you have to remove the trim piece that goes down the a-piller...
04-29-2005, 12:55 PM
#14
Registered User
Twister, E, Thank you both for good info.
I have seen so many posts I "swear" I had them latched and of course people think they did not. I even tug on mine a bit when I put them back on because I also thought maybe they did not check them good......
I will be checking my pins BEFORE I go to the track this weekend.
Thanks again.
01 Trans Am WS6, M6 ASC# 3201
All options - T/C, Ebony and Camel interior
PERFORMANCE MODS: 420.5 HP 394.2 TQ 12.25 @117.36 60" = 2.060
TSP 228R, PRC 5.3 RHs, QTP's with catted Y, Asp, HS Rockers, Jantzer TB, !Baffles+sealed airbox,Factory Hurst w/LSS, Magnaflow Catback, Direct-flo lid, Holley Pwrshot, 160 Deg Therm, NGK TR55IX plugs, Raptor shift light, HPT Tuned.
SUSPENSION/DRIVETRAIN MODS:
Strange 12 Bolt 3.73 with LPW Cover, BMR LCA's PHR , TQ arm STB & SFC's,Polished ZR1's with Nitto 555 Extremes on frt 315 Dr's on the back
COSMETIC MODS:
Black 30th Annv stripes, Black Nose Bird, Black over/inlays, 5% tint all around, Cyberlight Fogs.
PICS
04-29-2005, 02:03 PM
#15
Light em up Racin
checked mine they werent to bad but they are good now!!!
04-29-2005, 03:43 PM
#16
:love:
One more thing to consider. Make sure they are not TOO tight because when the body flexs, one of the main absorption point is the roof. Of those metal mounts are too tight to the T-Top, you can shatter the glass...Leave a little space but make sure they are still securing the T-Top pins
2002 Black Trans Am Firehawk M6 #1335
1 of 318
390rwhp / 370rwtq
Mods: VRX4 Cam, TEA Dual Springs, SVO Injectors, Strange 12-bolt w/ 3.73's, Kooks LT w/ catted Y, SLP DD, TSP Smoked Lid, WS.6 Lower Airbox, !Baffles and sealed to airbox, Ported TB, BMR Bolt-on Relo Brackets, Red CETA Filler Panel, SLP Bellow, SLP Bolt-on SFC's, BMR STB, LSS, DEI 530T Auto Up/Down, !AIR, !CAGS
07-04-2005, 03:41 PM
#17
StickItOnAndStickIt
Great thread.
I checked mine yesterday.
Had pins inserted 1/4 inch. Was able to adjust to 3/8.
Thanks
07-07-2005, 01:13 AM
#18
Member
Never a problem, that is why we are a community. Everyone that benefitted from this thread needs to send me 50 dollars (think of how much money we saved you, 50 isn't a lot to ask!).... I will be waiting.
07-07-2005, 01:15 AM
#19
Um... hold your breath and see if your face will match the color of the shirt in your avatar!  The check is in the mail!
07-07-2005, 01:12 PM
#20
Member
Can I breathe now? I still haven't seen a check.....maybe the mail is running late!
07-08-2005, 02:50 AM
#21
Registered User
Great info. I'll have to check mine, I never knew this was such a big problem.
07-08-2005, 04:39 PM
#22
Senior Member
You guys scared me. Checked mine as soon as I got home, they were both fine though. Great info though.
07-11-2005, 04:39 PM
#23
Senior Member
Nice info.. Im going to check mine today, I would not want to lose a T-Top again
07-17-2005, 05:04 AM
#24
Nobody needs a catback...
Great post, my ttops have always been a little loose, i will definately check them 2morow
07-17-2005, 07:16 PM
#25
Stanley Cup Champs!!!!! :Party:
E, perhaps we could copy this to the "How to/Methods and procedures" section?
07-10-2006, 02:02 PM
#26
Member
Thats funny, I have a vette in the shop now with the targa top scratched down to the white fibers. He said it blew out on the interstate. $1000.00 gone in the wind....
Williams Auto and Performance
www.wapracing.com
