Go Back   LS2 Forums > General Technical - F-body, GTO, C5, C6, CTS-V etc > General Technical Discussion
EFI Live  LS2.com Sponsor Information  Centerforce
Page generated in 3.25472 seconds with 16 queries [Server Loads: 2.63, 1.34, 1.04]
Old 02-17-2004, 05:59 PM   #1
eboggs_jkvl
98 Tank Access Door
Here we go. This is the before and after shot.
Action
Remove cover from Amp and unfasten amp from mounting screws.
Remove both side panels with speakers.
Roll back carpet
Drill pilot hole and plan remaining cut.
Note: We drilled with large drill bit and taped the bit with a lot of electrician’s tape about a ½ inch from the end to insure that we stopped before we hit the fuel tank!
Expanding the Hole We marked the outline of the rectangle we wanted.
We used a nibbler to finish the cut of the hole
Closing the hole
We took galvanized metal and cut out a rectangle to cover the hole.
Marked off screw holes and then drilled the holes in the cover and the floor.
We used a piece of tarred insulation to seal the cover against water or air leaks.
All, done. Back where we started. 2 Hours tops. I would recommend that you cover the nibbler to keep the “nibbles” from flying all over the place. I’m still vacuuming those darn things and I’m finding them in the front seat!
2007 Corvette, Victory Red, MZ6, Z51, Convertible
eboggs_jkvl is offline   Reply With Quote
Old 02-17-2004, 06:07 PM   #2
jumpcable
Look at ME!!
jumpcable's Avatar
Looks good...I'm assuming this allows a quick way to change out the fuel pump in case it goes bad. - Patrick
2007 Pontiac G6 GTP - 3.6L DOHC VVT
Stock DD
1998 Camaro Z28 - 6.0L 408cid LQ9
* Forged Rotating Assembly * TTi Street Kit w/ T76 Turbo @ 4psi * 3.73 Gears * Racetronix Fuel System * LS6 Intake * Motron 60# Injectors * 2 BAR MAP (SD Tune by Brian)
jumpcable is offline   Reply With Quote
Old 02-17-2004, 06:09 PM   #3
AtomicVette
Registered User
Nice.. BTW.. did you know there's an Arm growing out of your seat?!?
2007 Atomic Orange
LG Long Tubes
Veraram Intake
AtomicVette is offline   Reply With Quote
Old 02-17-2004, 06:14 PM   #4
eboggs_jkvl
That's the "arm mod" Big bucks...
Yes, the door is to gain access to the fuel pump assembly
Old 02-17-2004, 08:25 PM   #5
jumpcable
Look at ME!!
jumpcable's Avatar
Makes you wonder why wouldn't a car company incorporate this type of mod into the design of their cars. Sure makes it a hell of a lot easier to work on....oh yeah, they are more worried about apeasing themselves. Sorry, almost forgot for a second there.
Old 02-17-2004, 08:57 PM   #6
FirehawkNS
That's "Foreskins" to you
FirehawkNS's Avatar
Send a message via AIM to FirehawkNS
Hey that first and last pic are the same, not a before and after!!
1999 Pewter Z28
Flickr
1999 Z28, 2004 Acura RSX, 2001 Blazer LT
FirehawkNS is online now   Reply With Quote
Old 02-18-2004, 01:27 AM   #7
eboggs_jkvl
Ya got me there. It's hard to tell because we did such a good job!
Old 02-18-2004, 01:55 AM   #8
Get Shorty
Registered User
Get Shorty's Avatar
Send a message via AIM to Get Shorty Send a message via Yahoo to Get Shorty
Did you do this before or after your fuel pump went out? Y'know, as a "just in case"?
Excellent idea, though... Better than dropping the tank.
Get Shorty is offline   Reply With Quote
Old 02-18-2004, 02:35 AM   #9
jmd
Too many people suing over gas tanks in Fords, NBC blowing up pickup truck fuel tanks, and a mass of paranoid people who think they're gonna die.
Look at what they did to the Monaro fuel tank setup to make the GTO.
jmd is offline   Reply With Quote
Old 02-18-2004, 03:06 AM   #10
eboggs_jkvl
The walbro I have got in with the tank being dropped. My sending unit went bad so I figured I'd just do the hole this time rather than drop the tank. I figure, it'll save me a LOT of time on any other fuel tank entry.
Old 05-12-2004, 03:52 PM   #11
98 SNAKE EATER
Send a message via AIM to 98 SNAKE EATER
My sending unit recently went out as well (2nd F'ng time!!)
What length are the sheet metal screws you used
I'll be doing this on Saturday night, so I wanna make sure I get all the parts I need beforehand....
Rick
98 SNAKE EATER is offline   Reply With Quote
Old 05-12-2004, 04:02 PM   #12
eboggs_jkvl
Probably 1/2 inch screws. They really don't need to be very big. 2 pieces of sheet metal and the tar strip insulation and sealant isn't very thick. You have a good inch of space under the floor befor you touch tank. You just need to watch out for plumbing and wiring as you reassemble.
Old 05-12-2004, 04:57 PM   #13
Blk00z28
Danger
Blk00z28's Avatar
Send a message via AIM to Blk00z28
Man Snake, you brought this from the past.. lol
So why is it "98 tank access door" do the 99-02 have something different? I didnt think they changes anything other then the size of the tank, just a little though.
91 GMC Syclone # 1713 <--12.32 @ 108.39, 1.73 60'
Stock engine & internals, PTE61, TCS 9/11-2800.
Black 2000 Z28 M6
13.685 @ 104.17 w/ 2.158 60'
Blk00z28 is offline   Reply With Quote
Old 05-12-2004, 05:07 PM   #14
eboggs_jkvl
One is metal, the others are plastic 99+. The sizes are different and they relocated the hole slightly on the plastic ones.
Other than that, no difference.
Old 05-12-2004, 05:27 PM   #15
Blk00z28
Danger
Blk00z28's Avatar
Cool, but hell either year, that would come in handy if you ever have to changer the sending unit.
Black 2000 Z28 M6
Old 05-12-2004, 05:31 PM   #16
slow
1998 Ws6 M6 #370
Send a message via AIM to slow
aslong as you cut in the right place.
following a 98 guide on a 99+ car, or a 99+ guide on a 98 car, won't allow you to get the job done
Ryan.
slow is offline   Reply With Quote
Old 05-12-2004, 06:24 PM   #17
Constrictor
Registered User
Constrictor's Avatar
Send a message via AIM to Constrictor
I will do this mod one day...but it'll probably be when the time comes that my fuel pump ever goes out!
1998 Bright Red Pontiac Trans AM A4 405.5 RWHP 385.1 RWTQ
CHS Stage 2 5.7L Heads; 228/224 112LSA cam, Hooker LTs, LS6 Intake, ASP, Modified Loudmouth, Custom Y, Carsound 94009 Cats, Strano Re-valved Bilstens, BMR Springs, BMR SFCs, BMR STB, Custom Stereo, U.S. Exotics WS9 hood + many other performance and appearance mods
2004 Nighthawk Black Honda Accord EX Coupe
255 HP 3.0L VTEC V6; 6 speed manual transmission
2005 Pearl Magma Red Kawasaki Mean Streak
1552 cc V-Twin Cruiser; lots o' chrome!
Constrictor Trans Am and Death to a Monsoon webpage: http://www.constrictorls1.com
AOLIM Name: Eckmanmj (if you IM me, please identify that you're from LS2.COM, I am not kidding, if you can't follow this simple instruction, I will ignore you!!)[/size]
Constrictor is offline   Reply With Quote
Old 05-31-2004, 04:37 PM   #18
98 SNAKE EATER
Lightbulb
OK, here are a few pix from my Sender Unit install
Too much junk in the trunk....
Remove Sidepanels.....
Pull Carpet Back....
Air Shears and Nibbler....
It's hard to keep the Nibbler in a straight line, so I just used the Shears after drilling a small pilot hole....
3 straight cuts to make a Doggie door....
Pry Doggie door back to gain access......
Unbolt Retaining Ring and Remove Fuel Pump Assembly
Replace Fuel Pump with New Sender and Close Doggie door....
Measure and Cut Sheet Metal Cover Plate.....
Didn't have any Tar Strips on hand, so I improvised and layed a thick bead of Black Silicone around the perimeter of the access panel as well as the edges of the Doggie door itself....
After Laying the Sheetmetal Cover in place, I used a VERY short drill bit to drill 6 small holes around the cover, then screwed it down using 1/2" Phillips Head Sheet Metal screws....
Once it was screwed down, I went ahead and drilled 10 more holes to help distribute even pressure around the cover plate....
After the Silicone was completely dry to the touch, I put the carpet back in place, re-installed the sidepanels and put all my junk back where they were.....
Gauge seems to be working fine
At the Gas Station, I left the Ignition on and watched the needle rise as I filled her up
Rick
Old 06-01-2004, 01:25 AM   #19
99huggerorangeZ
project pumpkin
99huggerorangeZ's Avatar
Send a message via AIM to 99huggerorangeZ Send a message via Yahoo to 99huggerorangeZ
has anyone with a 99+ fbody done this mod and if so do you know where they relocated the access hole to the fuel pump??
1999 Hugger Orange Z28 M6
28,000 miles
GMMG Exhuast,SLP Lid,SLP Smooth Bellows,KN Filter,SLP Ram Air(SLP Flowpac),CAGS,!AIR,!EGR,
More mods to come....F.A.S.T. LSX 90mm Intake Manifold w/Nick Williams 90mm TB,Comp XE-R 232/240 .595/.610 112 LSA ,QTP Equal Length 1-3/4 LT Headers,QTP ORY Pipe W/Dual QTP Electric Cutouts
99huggerorangeZ is offline   Reply With Quote
Old 07-07-2004, 02:55 AM   #20
XTNKT
Registered User
XTNKT's Avatar
try this
http://www.ls1tech.com/forums/showth...=136171&page=3
XTNKT is offline   Reply With Quote
Old 07-07-2004, 02:19 PM   #21
eboggs_jkvl
THis is really easier to locate than you might think. If you use a hole saw Geographically dead center you can locate the sender assembly and then adjust the exact location of the rectangular cut. You simply need to tape the hole saw so you don't push down on to the piping and wiring. Wrap masking tape around the hole saw about 1/4" up from the teeth of the bit. A thick layer of tape will stop the hole saw from damaging anything under the metal. That way you can do the project and custom cut your door. You can't reuse the OEM piece of sheetmetal that you cut as it will just lay there as a non supportive flap. The new "door" you put in to cover the hole will be the support and allow you to put in the water seal and sound deadener like Nick did.
Old 07-13-2004, 01:01 PM   #22
98 SNAKE EATER
Angry
OK, this is really starting to chap my arse
Over the last week, I've noticed the gauge acting funny again
If I fill the tank completely, the gauge reads full and won't budge until I drive at least 115 miles
Then it proceeds to gradually move to "E" as I finish up the rest of the tank
Now, as a test, I drove it till the gauge hit "E" (even though it's highly frowned upon), then hit the gas station...
The tank would only take 11 gallons, which meant I had 4.5 gallons left (either that or the gas pump was f#ckin with me)
Luckily, there's a 12 month warranty on the sending unit, so I'm in the clear, but what exactly would cause it to go bad in just 2 months time
Old 07-13-2004, 08:11 PM   #23
jmd
Rick,
Your last name is Murphy, and you must abide by the Law. :
2 months? Dunno. Not corrosion that quick, that's for sure. Have you measured what values it's giving you currently?
Old 07-13-2004, 08:18 PM   #24
98 SNAKE EATER
LOL, true.....
I have yet to pull it, but when I do, I'll check the readings....
New one should arrive tomorrow, but I'll wait till this weekend to throw it in
Old 07-13-2004, 10:14 PM   #25
slow
1998 Ws6 M6 #370
rick, do you have that part number, that you can send me or post on the sending unit.
and for going bad in 2 months... around memorial day, you didn't get any shell gas in the tampa area did you?
I did... my sender is screwed, 140 miles before it goes off of full .. they will pick up the tab of $1049 to get it done at the dealer.. but i don't want my car going to dealer for that repair
Ryan
Old 07-13-2004, 11:43 PM   #26
98 SNAKE EATER
Damn!!
$1049??
Think you can make me a copy of your Shell receipt?
No, I didn't buy any Shell or Marathon gas
I stick to BP Connect/Amoco, Chevron and Mobil (Sunoco 94 if I'm up North)
The part number for the Sender is 25314260
Rick
Old 07-14-2004, 04:07 PM   #27
98 SNAKE EATER
Angry
OK, looks like the $h!t's about to hit the fan
I just got a call from my GM parts supplier and he said there has been a large amount of fuel senders going bad due to the bad batch of gas out there
Well, I already knew that Shell and Marathon had this problem, but didn't think it concerned me cause I never use their gas
Turns out that Chevron and Amoco Fuels were both tainted as well, but they didn't go public until recently
Now, I'm just going by what my supplier and his shop foreman says and have yet to find an actual news regarding this, so if anyone has a link to more info, please post up....
Anyhoo, my supplier said that if carbon deposits from sulphur are detected when the foreman checks the unit, it will void my warranty
I went to BP's website and they don't have a phone number listed
Who do I need to contact
Hi, my name is Murphy and I got this Law......
Old 07-14-2004, 04:27 PM   #28
slow
1998 Ws6 M6 #370
Thanks rick.
I normally don't get shell, i even pulled off I4, only was a shell station, got back on I4, next exit, was shell, and some no name brand, so i went with shell... bad move on my part :/
Thanks for the part number, i'll just order it now and do the repair myself,
Ryan.
Old 08-04-2005, 02:55 PM   #29
Dolemite
Defeat Socialism!11!!!!11
Dolemite's Avatar
I just had a quick question.
My fuel pump went bad on my car....it's a 96 Formula.
I was wondering if your 'fuel pump removal door' mod can also be applied to LT1 cars. I'm assuming so...but I'm not sure
Also...one thing isn't clear to me: Would I be drilling in hole into the metal? Or also the actual gas tank? Am I going to be cutting into the actual tank to remove the pump? Or just the metal housing it?
Dolemite is online now   Reply With Quote
Old 08-04-2005, 03:10 PM   #30
Get Shorty
Registered User
Get Shorty's Avatar
I'm pretty postive it's the same.
Oh, and use screws short enough to not puncture the tank.
Old 08-04-2005, 03:16 PM   #31
Dolemite
Dolemite's Avatar
Okay, so basically, I am just drilling into the metal trunk area covering the tank? Not the tank itself?
How hard is to actually replace the fuel pump afterwards?
Old 08-04-2005, 03:51 PM   #32
Get Shorty
Registered User
Get Shorty's Avatar
Correct.
I've never replaced one on an F-body, so I couldn't tell you for sure. I know it's not normally a big deal though.
Old 08-05-2005, 04:01 AM   #33
jmd
simple.
Old 08-05-2005, 01:05 PM   #34
eboggs_jkvl
With the door it's simple. Open door. Remove ~6 fasteners, disconnect the hoses, lift out and replace. Reverse order and you're done.
That sure beats put car on lift. remove exhaust, drop one side of PHB, remove fuel tank shield, remove fuel tank straps, drop fuel tank, remove ~6 fasteners, disconnect hoses, lift out and replace. Reverse order and you're done.
Ok, now, you pick the easiest of the two procedures?
Old 08-05-2005, 10:10 PM   #35
Dolemite
Dolemite's Avatar
Okay...I am going to probably tackle this weekend with my father.
What should I use to cut the holes? What kind of tools should I use, and how should I avoid sparks?
Old 08-05-2005, 11:12 PM   #36
zombie5011
Member #613
zombie5011's Avatar
My car normally stays on full for 100+ miles and the 1/2 mark around 200ish... then rapidly shoots down to E around 300-325 miles.
zombie5011 is offline   Reply With Quote
Old 08-06-2005, 05:35 PM   #37
FlagSStaff
Registered User
FlagSStaff's Avatar
Send a message via AIM to FlagSStaff
That's the level sensor thingy being retarded. Mine stays on full for ~200 miles, then slowly works its way down. One of these days I'll get enough motivation to do the hole like E did, but I know what mileage my car gets, so no worries...lol
FlagSStaff is offline   Reply With Quote
Old 08-07-2005, 02:57 AM   #38
98 SNAKE EATER
It's usually carbon buildup on the variable resistor caused by $hitty gas and even $hittier GM parts
You can pull the sending unit out, rub off the carbon with an eraser and you'll be good to go until it gets gunked up again
I've had to do this once already after replacing the sending unit
Old 10-23-2005, 08:15 AM   #39
ANTIVNM
Registered User
hell, I just siliconed mine back down.
ANTIVNM is offline   Reply With Quote
Centerforce
Showroom FX
KOOKS Custom Headers
Minty Fresh Productions
Powered by WebRing.
Submit Your Website to Search Engines for FREE
Site Owner: Eric Boggs -- Copyright © 2004 - 2010, WWW.LS2.COM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
