Page generated in 0.13316 seconds with 25 queries [Server Loads: 0.64, 0.56, 0.48]
06-01-2007, 12:32 AM
#1
post pics of wot
im not sure how to mount the wot switch can anyone post pics
Thanks
- mike
06-01-2007, 08:06 AM
#2
Super Moderator
Is this for your '93?
There's a mod here that goes by "TheBiZ" that has sprayed LT1 motors for a while.
06-01-2007, 08:12 AM
#3
Bone Stock..True Story.
Give me a sec and I will look for a pic.
06-01-2007, 08:21 AM
#4
Here is what I could come up with from my personal pics. You can't see the WOT switch too well, but you should be able to get the drift.
Use the bracket that comes with the WOT switch. Run the bottom right TB bolt through the bracket and then bend into position. Make sure the dog ear on the TB (circle A), hits the switch (circle B) only when the butterflies are ALL THE WAY open. Its really a trial and error thing. There is no "wrong" way to mount it. As long as the switch is down when the TB is wide open.  Let me know if you have anymore questions.
06-01-2007, 08:52 AM
#5
Super Moderator
06-02-2007, 03:44 AM
#6
It was an LT1, all that excitement and not enough motor to release it all...if you know what I mean.  I have remedied that tho.
Lower Navigation
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
