Go Back   LS2 Forums > LS1, LS2, LS3, LS6, LS7, LS9 | F-Body, GTO, C5, C6, CTS-V LS2.com > Tuning | Computer | Electronics | DTCs
Parts For Your Car  AMS Racing  EFI Live
Page generated in 0.26796 seconds with 33 queries [Server Loads: 0.47, 0.50, 0.44]
Reply
Thread Tools Display Modes
Old 08-27-2010, 02:25 AM   #1
JimmyJazz
ECU E40 Help
Hello All
I have just aquired an LS2 complete with ECU E40. factory engine loom and throttle pedal. I am going to install it all in a 427 cobra and am hoping somebody can help me with the pinouts and what wires I need to get it running.
Thanks for the help inadvance.
Alan
JimmyJazz is offline   Reply With Quote
Old 08-27-2010, 03:19 AM   #2
HSV-GTS-300
Marsupial
HSV-GTS-300's Avatar
Hi Alan,
E40 Pinouts here.
http://www.ls2.com/forums/showthread.php?t=833000
Posts #22 to #24
You'll have difficulty using an engine harness without the BCM & PIM from the original car. You'll also need to get the VATS turned off.
It may be far easier to contract a specialist company to re-work your stock GM harness, turn off the VATS and provide you with a tune.
Examples below:
http://www.hotrodlane.cc/PDFFILES/ls...nessSquire.pdf
http://www.speartech.com/
Click on LS-24X
"If your engine came with the original harness attached, and you want to save a few bucks, send it to Speartech for a stand-alone conversion. We'll add all the great features that are part of our new custom harnesses.
If the overall condition and appearance of the original harness is satisfactory to you, and the placement of the computer will work for your application, then reworking the original harness can get you up and going quickly and save you some money.
We will eliminate unnecessary wires from the harness and simplify the hook up end, adding the same features as our brand new harnesses, including a check engine light, a diagnostic connector, a fuel pump relay, as well as ignition and battery power up wires. When applicable, tach and gauge wires are also brought out for your convenience."
HSV-GTS-300 is offline   Reply With Quote
Old 08-27-2010, 04:44 PM   #3
JimmyJazz
Quote:
Originally Posted by HSV-GTS-300 View Post
Hi Alan,
E40 Pinouts here.
Posts #22 to #24
Thanks for the reply, I forgot to mention that the engine is out of a vauhall monaro vxr. I have looked at the pin out you gave me and a few of them appear to be different. Is there a specific one for the monaro.
Old 08-28-2010, 02:05 AM   #4
HSV-GTS-300
Marsupial
Quote:
There'll be a few minor variations within the E40 family, with yours having the extra ability to handle the 90mm ETB and twin wire knock sensors amoungst other things.
Post up a couple pics of the E40 you have, complete with Part No & Service No.
(The Pinouts I gave you were for a 2005/2006 Pontiac GTO which I would have thought to have the most in common with what is in front of you).
Old 08-28-2010, 10:21 PM   #5
JimmyJazz
Here are some pics of the ECU as asked for.
Thanks again for the help
Old 08-29-2010, 02:34 AM   #6
HSV-GTS-300
Marsupial
A bit of online searching found 12596733 YKWB listed as from 05 GTO M6.
I don't have any info specific to 2005 Vauxhall VXR
What are you noticing thats different between the pinouts posted and whats in front of you? Just wire colours??
Old 08-29-2010, 03:59 AM   #7
JimmyJazz
There are only a few differences, they are as follows
C1 Plug Blue
No pin out on 4 mil light
Pin 18 bn/wh not ye
Pin 37 bn/gn not pu
Pin 48 bn/rd not bn
C2 plug Black All pins and colours correct
C3 plug Grey
Pin 22 not there
Pin 24 bn/ye not bk
Pin 34 bn not bk
Old 08-29-2010, 05:14 AM   #8
HSV-GTS-300
Marsupial
Excellent, thanks for the concise info.
I've looked at everything I have for pinouts on E40's and have nothing here which matches whats in front of you.
One source showed different C1 & C3 pinouts for 2005 Corvette with M32 (4 speed auto) V MM6 (6 speed manual).......but still nothing close to what you have. No clues found there.
Same source showed similar pinouts on C3 on 2006 TBSS LS2 truck to what you have, though C1 was not similar to yours.
I'll try to chase up some Holden VZ tech info which may have exactly what we need.
Old 08-29-2010, 04:58 PM   #9
JimmyJazz
Thanks for the help. I'll keep my fingers crossed that you turn something up. Meanwhile I'll keep digging myself.
Alan
Old 09-06-2010, 05:13 PM   #10
JimmyJazz
C1 Plug Blue
Pin 18 bn/wh not ye
Pin 37 bn/gn not pu
Pin 48 bn/rd not bn
C3 plug Grey
Pin 22 not there
Pin 24 bn/ye not bk
Pin 34 bn not bk
I've traced all the plugs back to the pins and they all work out regardless of colour so I think I'm going to be OK.
I just have a couple of other questions
How do I wire the OBD plug ie which pins in the obd plug need what wires
How do I wire the yellow wire Pin42 pluc C1 reverse lockout
Old 09-09-2010, 08:13 AM   #11
HSV-GTS-300
Marsupial
Alan
I struck out, the guy didn't have Holden VZ ECU pinout info.
That's great news.
I only have GM tech info which doesn't cover such dastardly deeds.
The aftermarket Harness guys have figured out how to achieve these functions & I guess they wouldn't give their hard earnt info up easily.
Here's a thread with the only info I have on OBD2 for GTO:
http://www.ls2.com/forums/showthread.php?t=838440
Old 09-15-2010, 03:47 AM   #12
carl0s
fabo-matic
carl0s's Avatar
All the information you seek is in the various information used by the V8 RX7 people.
Have a look at http://www.norotors.com and download BurtonCR's spreadsheet of the GTO wiring guide.
Your OBD pin outs are on there. It's CAN-HI from PCM C1 connector to OBD pin 6, and CAN-LOW from PCM C1 connector to OBD pin 14, plus ground on pins 4 + 5, and 12v constant on pin 16.
The reverse lockout is a ground connection, so you can just run that wire on the big white connector to ground to un-lock reverse, but the gates are very close together on this box, so it's best to keep the reverse lockout. It should still work anyway with the PCM control.
I recommend you read the spreadsheet I mentioned anyway.
carl0s is offline   Reply With Quote
Old 09-16-2010, 05:35 AM   #13
HSV-GTS-300
Marsupial
Thanks to Burton
Old 03-10-2013, 12:01 AM   #14
suenjimt
Stand alone 05 pinout needed
I am new to ls2 engines.
I have a 05 GTO LS2 24X T56 tranny. I am looking for a STAND ALONE pinout assignment diagram. Nothing tricky, just a simple diagram with pin number, circuit number and function for stand alone operation
Thanks
Jim
suenjimt is offline   Reply With Quote
Reply
Lower Navigation
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
LMPerformance Inc
Edelbrock Performance Suspension
COMP Cams
Fuelie Guitar Pickups
LS2.com Sponsor Information
LS2.com Store
AMS Racing
JEGS
Nasty Performance
mjm autohaus
SPAL USA
NFL Gear 4 Less
GM Inside News
Brown Line Metalworks, LLC
General Motors Western Region Communications Team
Speed South
GM Powertrain Information
Site Owner: Eric Boggs -- Copyright © 2004 - 2013, WWW.LS2.COM
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
