Go Back   LS2 Forums > LS1, LS2, LS3, LS6, LS7, LS9 | F-Body, GTO, C5, C6, CTS-V LS2.com > Nitrous
COMP Cams  General Motors Western Region Communications Team  AMS Racing
Page generated in 0.16436 seconds with 28 queries [Server Loads: 0.77, 0.56, 0.48]
Reply
Thread Tools Display Modes
Old 01-04-2008, 07:58 AM   #1
red metal
Telling it how it is.....
red metal's Avatar
Send a message via AIM to red metal
Post Who is spraying below 3000rpm?
Mostly curious about the M6 guys on stock 10bolts.... but all others, A4's ect..., put your thoughts and experiences on the table
So far the lowest I have sprayed is 2600 using my progressive controller. I run a stock 10bolt with 3.90's running on Nitto DR's so I slip the clutch out of the hole and roll out then the nitrous starts to kick in.
This weekend I plan to bring it on around 2400 at X% and full on by 3400. I will be running a 125(flywheel) shot....... dry is the key
red metal is offline   Reply With Quote
Old 01-04-2008, 08:05 AM   #2
5letr
2006 GTO
Red metal - What type progressive controller are you using? Where did you get it? Would you recommend it?
Frank
5letr is offline   Reply With Quote
Old 01-04-2008, 08:14 AM   #3
red metal
red metal's Avatar
FJO mini controller
I will pm you who I got it from, he is not a sponser on this board
I would recommend it, it is so easy to work with. The soft ware is great, with graph's ect...and you can pick one up for a touch of $200 bucks
Old 01-04-2008, 08:47 AM   #4
QWIKLS1
Super Moderator
QWIKLS1's Avatar
Send a message via AIM to QWIKLS1
My on pill is 3600.
Most of the time traction is my limiting issue. All spraying earlier does for me is spin the tires harder.
Car is a cam/boltons A4 car putting 401/385 down (N/A numbers) + a 100 shot (dry).
I have a few suspension mods (TA, LCA's, SFC's) and drag radials to help it hook.
QWIKLS1 is online now   Reply With Quote
Old 01-04-2008, 09:12 PM   #5
Chopstix
Send a message via AIM to Chopstix
The issue you will run into is if for some reason the car bogs, you are going to drastically increase your chance of an intake backfire.
The FJO controller is a very nice piece...it gives you the ability of ramping the nitrous by RPM or by time. It also allows you to program a ramp "curve" instead of just linear ramping.
The only down side is it requires a laptop to interface with, as all programming is done in a windows based application.
NOS just released a new product called The Launcher, which gives you the same abilities plus data logging and A/F shut down, and does not require a laptop. But does cost a little more.
Chopstix is offline   Reply With Quote
Old 01-05-2008, 09:00 AM   #6
red metal
red metal's Avatar
Yeah I really like the FJO piece. I am really interested in that new Dry Maf setup that NX is getting ready to put out. Should be a great part to help with A/F reliability!
Old 01-05-2008, 09:04 PM   #7
red metal
red metal's Avatar
Re: Who is spraying below 3000rpm?
Quote:
Doesn't look like I will get to try out the new FJO settings this weekend, my wife is coming along with me to the track and here is a pick of were I mount the bottle.
http://www.fquick.com/garages/viewga...ewimg&id=59004
Old 01-12-2008, 06:19 AM   #8
red metal
red metal's Avatar
Chopstix I just realized that you work where I buy my stuff from..... Are you a sponser elsewhere??
Old 11-25-2008, 11:59 PM   #9
STANG KILLA SS
STANG KILLA SS's Avatar
Send a message via AIM to STANG KILLA SS
i sprayed my 100 dry off the line. never any problems after 3-4 years.
STANG KILLA SS is offline   Reply With Quote
Old 11-26-2008, 09:51 PM   #10
TARZAN
Things are well
TARZAN's Avatar
It shouldn't matter because you shouldn't be dropping that low between shifts when you're racing anyways....and if you're spraying below 3000 and not going WOT you're comitting homicide to your bearings, so it won't matter for long.
-Will
TARZAN is offline   Reply With Quote
Reply
Lower Navigation
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
EFI Live
LS2.com Store
Edelbrock Performance Suspension
SPAL USA
LMPerformance Inc
GM Inside News
NFL Gear 4 Less
JEGS
Fuelie Guitar Pickups
Speed South
Brown Line Metalworks, LLC
Nasty Performance
LS2.com Sponsor Information
mjm autohaus
Parts For Your Car
GM Powertrain Information
Site Owner: Eric Boggs -- Copyright © 2004 - 2013, WWW.LS2.COM
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
