Thread: ls2 cam choice
    Apr 2010
    12
    ls2 cam choice
    My mods are ls3 intake, 42lb injectors, 3600 stall, untouched l92 heads, 3.73 gears, 90mm tb, long tube headers and suspension mods. The cam I was suggested specs are 231/236 640/610 111 lsa is that a good cam to compliment my ls2 combo?
    Marsupial
    HSV-GTS-300's Avatar
    Perth Australia
    16,217
    It would be useful to know the intended usage of the car and what you expect to achieve after the cam install.
    Apr 2010
    12
    Its just for a street car looking for at least 400rwhp hopefully
    Marsupial
    Perth Australia
    16,217
    This is what I'd use to get around 430-440rwhp with your combination.
    Comp LSr 223/231 .610 .617 114+2
    Similar to Comp 54-457-11 Grind No 273Lr HR12 but with a wider LSA.
