Thread: looking for LS1 oil flow diagram
    CT
    171
    Arrow looking for LS1 oil flow diagram
    does anyone have a pic showing the path of oil flow in the LS1, from pan to pump, thru oil filter and oil passages?
    or if anyone is sure, a brief description would be good.
    I have an oil temp sender mounted in the port just above the oil filter. I am wondering where abouts in the system that is, and whether I should be seeing high oil temps there or not. If my digital guage is correct, I am seeing 230F on average, and it'll peek to 240-250F when idling at low rpm's and not moving.
    2002 SS, black/tan, CME, M6
    Georgia
    93
    That would put yout sending unit in-line right after the pump, so that should be giving you a pretty good idea of temperature in the pan.
    However, before you get too worried, have you tested the sending unit/guage to see how accurate they are? The calibration may just be off.
    2001 Firehawk T/A #084
    1991 Firebird Formula
    1980 Trans Am Turbo Pace Car
