Thread: 2000 ls1 tps
    Banned
    Abilene, Texas
    303
    2000 ls1 tps
    ok i have tryed looking everywhere, i am installing an nx kit with the tps. which wire on the computer is the one for throttle position?
    QWIKLS1's Avatar
    Tempe, AZ- (Not near Palos Park IL)
    60,813
    5313
    Are you tying into it at the PCM or the throttle body?
    QWIKLS1's Avatar
    60,813
    5313
    If you're tying into the throttle body, it's the dark blue wire on the T/B and the white wire on the NX TPS switch.
    If you're tying onto the PCM, it's pin #24 on the second PCM bank.
    http://www.ls2.com/boggs/torques/00pinpcm.htm (scroll down about 2/3rds of the way and you'll see pin#24 on the second plug)
    Banned
    Abilene, Texas
    303
    thank you, there are lots of writups but none i could find had the info for the wires
