Results 1 to 21 of 21
Thread: Can my car pass emissions with an engine light?
    Registered Member thefritz1's Avatar
    CT
    5,421
    PSN ID: MDF812
    My car has been running fine (1999 Nissan Maxima) but the engine light has been on forever. The code is an ignition coil but I replaced them and it is still on. Can I pass emissions in CT with a check engine light if everything else is alright?
    Thanks!
    Registered Member triggerjerk's Avatar
    5,627
    I doubt it. Most states no.
    Go to autozone and get a hand held scanner and clear it yourself.
    Since it isn't emissions related, they should let you do it.
    Sometimes they won't let you clear ses lights. Depends on the state I think.
    Registered Member Camaro68's Avatar
    2,244
    341
    no
    NOT AT THE TRACK
    27,197
    you can clear the light, but then you'll need to do another drive cycle to activate all the sensors and get rid of the p1000 codes.
    Huge cock F1_SS's Avatar
    Auschwitz
    27,714
    In TX it wont pass with the CEL on.
    42,545
    On OBD-I, I have seen them pass a light truck w/ the CEL on. But your '99 is OBD-II, so I doubt it.
    -Detail Whore- Chameleon TA's Avatar
    Rowlett,TX.
    4,032
    Unplug the battery for a while. Then plug it back in and it should have cleared the code.
    2001 Speedway White Z06 1 0f 352
    -Vararam-Shaner S3-Air Bridge-Silicone Coupler-
    -B&B Bullets-LG Pro Long Tubes w/ High Flow Cats-
    -Kirban Shifter-Steering Wheel/Door Sill Decals-
    -C6 Z51 Rotors/Brackets-Hawk HPS Pads-
    -DRL/Tail Light Black Outs-C6 Knob-HUD-
    -CCW 19X10/19X11 SP500's Polished-Lowered-
    --Tropi-Care Dealer and Detailer PM me--
    I see you 89BB's Avatar
    Indy (not near Palos Park, IL)
    62,420
    Electrical Tape
    Registered Member AssumedZ's Avatar
    WI
    5,411
    Originally posted by Camaro68
    no
    Not in WI either
    I loled, No reSpect from crAzy Mr. Negative's Avatar
    New Jersey USA
    7,503
    1500
    Did you clear the code after the coil replacement? If not clear it and do a drive cycle to reset the readyness monitors. If the code doesn't reset, your golden.
    Registered Member carpenter's Avatar
    Green Bay
    31,345
    359
    Originally posted by AssumedZ
    Not in WI either
    we have emissions testing?
    Old Member blue02formula's Avatar
    Ravenna, Ohio
    4,498
    Not in Ohio.
    7,746
    1005
    Originally posted by 89BlownBrd
    Electrical Tape
    Nope. They check to see if the light comes on before starting the car. Plus, they'll see the tape
    WI
    5,411
    Certain counties do.
    Registered Member Checkmate's Avatar
    Virginia
    21,912
    reset the computer and drive quickly to the emissions place and hope for the best
    What type of test are they doing?
    WI
    5,411
    Originally posted by Checkmate
    rest the computer and drive quickly to the emissions place and hope for the best
    It'll still show OBDII should snag the code. If you fixed the problem and the code is still popping.... is it something else?? It's worth a shot, but I doubt they'd pass you.
    27,950
    427
    They passed a law a couple years ago in NY that all OBD-II and 1996-present model year cars need to have a clear code scan to pass.
    Virginia
    21,912
    Depending on what the code is for it can take a couple cycles of the ignition for it to come back. Pulling the battery cable will clear the history also.
    Or, if they are stupid and look for the SES light just cut the wire for the ses light. Not that I would recommend or do this.
    WI
    5,411
    lol Naughty
    CT
    5,421
    PSN ID: MDF812
    Yeah, I can't figure out what it is. But something is not agreeing because when I reset the light it still comes right back on. Car is running fine though--no misses etc. Strange.
    Virginia
    21,912
    What kind of car and what was the code? Maybe we can help.
