Results 1 to 21 of 21
Thread: Steel wool to get rid of waterspots on windows?
    Banned 1995blacktattop's Avatar
    Feb 2005
    who knows?
    18,218
    ok i was getting my car washed the other day and the guy drying the car said "you see those water spots on your windshield, you can use steel wool to remove them"
    i have never heard of this, nor do i intend to try it unless i know its perfectly safe for the glass. Has anyone ever sucessfully removed waterspots with steel wool? wouldnt that scratch the fuck out of the window?
    F-Body Enthusiast SylverStrypes's Avatar
    Mar 2006
    South Jersey
    708
    Yeah ive heard of it plenty of times. Apparently it does work. You have to use #0000.
    nWo SpecForceUS's Avatar
    Las Vegas, NV
    1,412
    It will work.
    Depending on the severity of the water spots, get #0000 steel wool. Get glass cleaner, and rub in circular motion.
    Now if this doesn't work, then you will have to get water spot remover, and use the steel wool. If you need to go this route, DO NOT leave the water spot remover once you finish steel wool on the windows.
    PM me for BERMANS ADDRESS Hillbilly Deluxe's Avatar
    444 FM 1463 Rd Katy Tx HBDLSW
    75,543
    yep you'll need the finest steel wool you can get.
    Use a generous amount glass cleaner, and LIGHTLY rub the area. You'll be able to see when the spots are gone.
    Its prety simple, but at the same time, its really easy to F up.
    aw dizzaamm ARman's Avatar
    602
    Like others have said use 0000 steel wool. I used a mix of water and vinager with steel wool to remove the waters spots because the acid in the vinager helped dissolve them.
    Webberville, MI
    33,425
    You can also use Barkeeper's friend or Bon-Ami and the risk of scratching the glass is ZERO. I wouldn't use steel wool.
    Ain't nobody chasin' me boy.
    Jack Daniels's Avatar
    Northern Virginia
    64,832
    590
    Wouldn't it be easier and safer to just use something like CLR applied to a rag?
    15,733
    We use steel wool at my shop to remove overspray on the windows........ Works great
    Then 333 lbs. Now157 lbs. -176 lbs! Mark's Avatar
    The Woodlands, Tx
    110,907
    1500
    Gamertag: ReefFreak
    #0000 steel wool and windex. Used to do it daily when I worked at a dealership back in high school.
    Feb 2005
    who knows?
    18,218
    for some reason the clear glass type window cleaners and rags dont seem to do the trick
    Going faster... BurnsRubber's Avatar
    SF Bay Area
    7,163
    I'd use a fine polishing compound before steel wool.
    Evyl Loves Me :bow: Euonym's Avatar
    May 2006
    All over the damn place
    4,411
    it will work fine. Glass is very hard. you're not going to scratch it steel wool unless you superman it. They use it to get overspray (paint) off windows too.
    Space and Time
    Sandman's Avatar
    Raleigh, NC
    8,243
    Have you tried a claybar?
    I'll move this over to Showcar.
    I'm the Dude man ws6dude's Avatar
    Dallas
    5,698
    I use a light rubbing compound on mine
    Registered Member NHRAMAN's Avatar
    Vancouver,B.C. Canada. W.Coast
    2,054
    I agree...I have been using steel wool for 20 years.works great.
    ALL BOLT-ONS.... LOW...At least 30 Aftermarket Goodies.....
    Aliquippa Pa
    8,852
    you can find synthetic steel wool pads at PepBoys-less mess
    Moderator ZeusJr's Avatar
    South Park, PA
    11,521
    I hate glass..
    Registered Member JRHAWK9's Avatar
    Lake Delton, WI
    737
    I just use a mix of vinegar and water......works everytime for me
    oh
    14,996
    yes... we've discused this many time here in the showcar and detailing forum
    SMILEY - Detailing Tuning etc - HSOMA
    2014 Silverado
    1999 Trans Am, White, M6 | SLP LM, WS9
    1998 Formula, Black, M6
    Dyno : 315 RWHP 326 TORQUE (before cam and headers)
    Mods : ASCD WS6 hood, GM lower airbox, Whisper lid, K&N, SLP LT, Random Tech cats, Borla (2/3 open), SVO 30# injectors, GM Hotcam, LS6 Springs, NGK TR55 (.052) plugs & MSD 8.5 wires, Kirban, T/A Girdle, SLP SFC (Bolt-ons), BMR STB, !PAS, Starter Button, Garage Door Button
    1989 20th Anniv Turbo Trans Am #264 | ....
    _________dot COM EVL LS1's Avatar
    GEORGIA www.EVLLS1.com
    1,708
    steel wool all the way.... only way you'll f it up is if you get the wrong # wool =)
    also works great on chrome, stainless, etc....
    Jax,Fl.
    140
    Try some zaino glass polish. It's awesome.
