Results 1 to 8 of 8
Thread: 2005 GTO LS2 Oil Capacity 5 Qts or 6.5?
    Registered Member bfitzpa1's Avatar
    Jul 2005
    San Diego. CA
    59
    I just got through changing my 05 Goat's oil with Mobil 1. The owner's manual says the capacity is 6.5 Qts. I only got less then 5 out with the filter removed. What gives? I checked for multiple oil drain plugs under the oil pan plate and there was only 1 plug, so I'm assuming no baffles. I'm going to check the stick with 5 qys in and see. I hope I did'nt leave some dirty oil in there somewhere.
    Attached Images Attached Images
    Jul 2005
    San Diego. CA
    59
    Stick Says 5 qts of fresh clean oil in the middle of the 'operating range', so I guess the owner's manual has a typo...
    ls1 Collector
    newjersey
    18,508
    6.5.
    99 Hugger y2y SS A4
    12.2@113.
    silver 6sp. 05 GTO.
    LPE CAI and magnaflow CB.hood baffles removed. skid plate.tune.nittos.
    365/361
    Jul 2005
    San Diego. CA
    59
    More then 1 drain plug?
    Smilie King :flex: NoRiceInside's Avatar
    Race City U.S.A.
    23,318
    no, front sump... So if you jack the car from the front or use ramps there is still some in the back of the pan... i use 6qt.
    8-3; Fee Fi Foo Fum SilverFlash's Avatar
    Indiana
    26,844
    it is 6.5
    Aug 2005
    Ocean View, Hawaii (Big Island)
    91
    I just had the dealer do my first oil change since free oil and lube service is included for the first 3 yr/36,000 mi. They put in 6 qts plus filter change and my dip stick showed low so I added 1/2 qt and it still was a hair under the full, so I believe the manual is correct at 6.5 qts with filter change. Are you sure you had the dip stick FULLY inserted? Also sometimes level ground isn't always as level as it looks. This could be decieving and affect the level on the stick. Aloha, from Hawaii
    REAL MEN GET BLOWN! JohnnyLS2's Avatar
    Minnesota.
    23,881
    6.5
