Results 1 to 21 of 21
Thread: Engine Masters testing filters.
    Registered Member mogs01gt's Avatar
    Mar 2004
    Ohio
    22,394
    491
    Steam ID: mogs01gt
    Engine Masters testing air filter set ups.
    I thought this was interesting. The amount of power killed was a lot more than I expected. I was assuming it wasnt going to be more than like 15hp killed.
    Registered Member Potent68's Avatar
    24,188
    200
    I found the stock Dodge air cleaner to be the most interesting. Single snorkel (2nd taped), both snorkels untaped, and lid flipped.
    Eraser Dope's Avatar
    Assachusetts
    15,991
    13970
    That was really great. I always thought velocity stacks adding power was a myth. Guess not.
    Dope
    :flirt: SwollHottie's Avatar
    TEXASS
    188,955
    2025
    that was an interesting one.
    they just released a new one where they swap AFR 165, 190, and 210 heads in succession on a 351-based stroker. results are not what you'd expect.
    In The Upside Down Gearhead SS's Avatar
    Dallas, Tx
    38,190
    Gamertag: Gearhead SS PSN ID: MorphWS6 XFIRE ID: MorphWS6
    Salad bowl you say?
    Registered Member speed_demon24's Avatar
    PC Florida
    18,505
    PSN ID: spddmn24
    Quote Originally Posted by SwollHottie View Post
    You could at least provide the link with the clickbait post.
    24,188
    200
    Quote Originally Posted by speed_demon24 View Post
    They release new episodes on the Motor Trend app a month before they become free on youtube so he probably couldn't.
    TEXASS
    188,955
    2025
    Quote Originally Posted by Potent68 View Post
    Correct.
    Mar 2004
    Ohio
    22,394
    491
    Steam ID: mogs01gt
    I want to see that!!!! They had previous episodes testing cams with certain heads and each time, the bigger head + normal size cam was their choice.
    I look reasonable, but I'm not. No F-bdy Bs's Avatar
    Next door. My folks live next door
    23,271
    2246
    Also a huge nod to early Mopar engineering.
    Those men knew wtf they were doing 60+yrs ago.
  11. #11
    Registered Member runningmole's Avatar
    San Diego, CA
    12,003
    1010
    Quote Originally Posted by mogs01gt View Post
    Ed Curtis & I'm sure other cam gurus, have been preaching that. I've only known about it for 15yrs when I started planning the lil stroker that when in my Fox. Im sure that knowledge had been around for a long time though.
  12. #12
    TEXASS
    188,955
    2025
    Quote Originally Posted by runningmole View Post
    you two really need to see the new episode when it's available on youtube
  13. #13
    Patronist esandes's Avatar
    Mar 2004
    Canada
    5,926
    449
    Cliffs?
  14. #14
    It'll get ya fat KrispyCharger's Avatar
    Mar 2004
    Detroit
    32,527
    1150
    Quote Originally Posted by Dope View Post
    Dope
    an ideal air inlet with a taper & curved lips always flows significantly better than open or even a straight cylinder
    you just have to understand air
  15. #15
    underdog 4 lyfe ill deuce's Avatar
    Mar 2004
    atoka,tennessee
    63,469
    Quote Originally Posted by KrispyCharger View Post
    that's why they made these, to smooth the turn.
  16. #16
    Mar 2004
    Detroit
    32,527
    1150
    That for sure still isn't an optimized length, I have a geometry generator somewhere that will give an ideal profile based on target flow rate and tuning RPM.
  17. #17
    The Battery King of South Georgia SIK02SS's Avatar
    Sep 2004
    Brunswick, GA
    39,962
    2500
    Gamertag: SIK02SS
    damnit, I'm running the #13 combo. looks like i need to put a solid top on mine. I don't think I have the room to run a flat base, and don't think I have room for a 4" filter with the drop
    edit: NVM, apparently it's capable of 650hp-ish. I'm calling it good on 420hp
  18. #18
    Coming Soon... Big_Red_1's Avatar
    Anoka, MN
    6,802
    250
    I've been watching a lot of these guy's videos.
    Thee x-pipe, h-pipe and straight pipe one was interesting.
  19. #19
    F*** Islam BlazedTech's Avatar
    Wylie
    3,999
    Be interesting to see in a wind tunnel.
  20. #20
    23,271
    2246
    Quote Originally Posted by Big_Red_1 View Post
    Summary?
  21. #21
    Anoka, MN
    6,802
    250
    Quote Originally Posted by No F-bdy Bs View Post
    Summary?
    X and H basically the same, but make more power than straight pipes.
