Results 1 to 14 of 14
Thread: Losing mph when racing 6litre l76
Hybrid View
Previous Post Previous Post   Next Post Next Post
    Mar 2014
    8
    I need some help on why I seem to lose mph when racing, just recently I have dropped from 117mph doin 11.4s to 113/114mph doin 11.6s in a vz SS 6litre my 60 fts are 1.634, my reaction is around .040 running street ets on 15psi, I just seem to be going down in mph my engine sounds normal and not getting much wheel spin and launches well but I'm at loss on why my mph is dropping when I'm pretty much racing with the same setup, the only mods is a cam and stall with 3.9 gears any help would be appreciated, I'm thinking of doin a compression test but the motor was built early 2015 thanks.
    SPECIAL DARK HOTCIVIC's Avatar
    KFC
    23,782
    3000
    You log the density altitude difference between runs?
    Registered Member Potent68's Avatar
    24,156
    200
    As HOTCIVIC said, I'd definitely look at what the weather was doing on those days.
    DANSBIRD's Avatar
    Mississippi
    161,771
    3804
    Like Potent alluded to, the weather may play a factor in the performance.
    LIFE IS GOOD HybridZ28's Avatar
    DFW, Texas
    28,816
    310
    Compression test and change spark plugs while you are there.
    How's the tune?
    Registered Member zo6pilot's Avatar
    Nov 2009
    MN
    5,996
    Raptr ID: 123456
    Quote Originally Posted by CHASEVZSS View Post
    Quote Originally Posted by HybridZ28 View Post
    How's the tune?
    Nah...I'd go with what Potent and Dan said bro...
    Registered Member speed_demon24's Avatar
    PC Florida
    18,489
    PSN ID: spddmn24
    How many miles are on the valvesprings?
    The Sax of Cars Anewconvert's Avatar
    Jul 2005
    Raleigh, NC
    14,358
    1301
    Have you considered what hotcovic, potent, Dan and hybrid have suggested?
    Mar 2014
    8
    Thanks for the replies, I will look into the time slips next week as I fifo at the moment but if I recall the times when I was running 117mph was only a few months ago and was fairly consistent in August track temp was about 21' degrees, where as in November I'm running close to 113/114 maybe a 115 mph if I'm lucky were track temp is 38-42' degrees, so it's a lot hotter but have noticed other racers are still running same if not a little higher than usual also. My engine was rebuilt back in early 2015 which had around 112k on the clock to this date it's on 118k I don't drive to much just mainly race it but it's full street car. That gives an indication how many miles the new engine has done, I replaced with new oil and filter and regularly change plugs to a .040 gap setting and it runs fine throughout with max rev range to 7000rpm. I was just thinking I may have damaged the engine internally for the low mph I am doin so constantly?
    Team Hobbit windham's Avatar
    Texas
    80,835
    Blog Entries
    2
    175
    I would consider what anewconvert said.
  11. #11
    KFC
    23,782
    3000
    21 c = 70 f
    38 c = 100 f
    I'm surprised you only lost 3-4 mph.
  12. #12
    Registered Member STANG KILLA SS's Avatar
    KILLEEN TX
    14,085
    fun fact: a stock LS(3) starts pulling timing (less HP) when coolant temps reach 212* or idle air temps reach 86*
    my fastest laps times (road racing) always happen on the first lap, before temps rise, and ecu pulls timing.
  13. #13
    24,156
    200
    *intake air temp
  14. #14
    KILLEEN TX
    14,085
    hahahahha yeah, thanks for that catch
