Thread: 2005 LS2 T56
    Aug 2017
    2005 LS2 T56
    If i,m going to use the stock engine and transmission harness is this all i need?
    1. Stock GTO engine and transmission harness
    2. Mass air flow sensor
    3. E40 J1 Harness Assembly Part #: 100-00471 for efi
    4. GTO pedal
    5. Fuel and Fan relay.
    6. fuel pump and wiring?
    7. Remove VATS
    What do i need to hook up on harness to make engine run ?
    Aug 2017
    found it on my own only took a few days here is the link http://www.802projects.com/rx7wiring.php
