Results 1 to 3 of 3
Thread: 2005 GTO wiring question
    Sep 2016
    I'm putting an 05 GTO drivetrain into a 1959 impala. I'm in the process of converting the original harness. Going well but I do have one question. Both the ECM and TCM have a yellow wire labelled accessory voltage. I find the double relay set up feeding this circuit a little confusing. Is it an accessory voltage feed from the ignition switch and does it need to be connected on a swap?
    Thanks in advance!
    386
    The GM factory service manual for that car is available here:
    http://www.auto-repair-manuals.com/G...FQp3fgodNnACLA
    Buy the book and look up everything you will ever need to know about the 2005 GTO
    Mar 2017
    8
    I have an 06 GTO powertrain in an 04 Miata. I'm beginning to research the yellow accessory wire too. Will report what I find here. Almost everything else is sorted.
