Thread: LS conversion throttle doesn't work
    Jan 2014
    The LS2 /4l65E conversion into a 79 Camaro engine starts and idles throttle wont rev engine, I see many answers but nothing definitive, whats the most likely thing? The engine and trans are out of 06 GTO where do you start?
    Jim
    6,799
    490
    Sounds like possibly a pedal/ecm mismatch.
    161,803
    3804
    You also may want to double check the adjustment of the throttle cable. When I did an engine swap in mine, it did something very similar.
