Results 1 to 3 of 3
Thread: Torques, PCM, DTC, General Information
    101,226
    Engine Controls Components Locations
    (1) EVAP Canister Purge Solenoid
    (2) Fuel Pulse Dampener
    (3) Fuel Rail with Injectors
    (4) Crankcase Vent
    (5) Left Bank Ignition Coils/Modules
    (6) Left Bank HO2S Sensor 1
    (7) Engine Coolant Temperature (ECT) Sensor
    (8) Fuel Pressure Gauge Test Connector
    (9) Throttle Position (TP) Sensor
    (10) Idle Air Control (IAC)
    (11) Throttle Body Assembly
    (12) Exhaust Gas Recirculation (EGR) Valve
    (13) Right Bank Ignition Coils/Modules
    (1) Idle Air Control (IAC) Motor
    (2) Throttle Position (TP) Sensor
    (3) Generator
    (4) Throttle Body
    (1) Mass Air Flow (MAF) Sensor
    (2) Intake Air Temperature (IAT) Sensor
    (3) Air Cleaner Housing
    (1) Manifold Absolute Pressure (MAP) sensor
    (2) Camshaft Position (CMP) sensor
    (3) Oil Pressure switch
    (4) Connector to Knock sensor jumper harness
    (1) Front Knock Sensor
    (2) Rear Knock Sensor
    (1) AIR System Crossover Hose
    (2) Air Inlet From AIR Pump
    (3) Left Bank Check Valve
    (4) Left Bank AIR Tube
    (5) Right Bank AIR Tube
    (6) Right Bank Check Valve
    (1) AIR Pump Location
    (1) Air Cleaner Housing Top Cover
    (2) Seal
    (3) Air Intake Duct to Resonator
    (4) Clamp
    (5) Air Intake Duct to Top Cover Retainer
    (6) Intake Air Temperature (IAT) Sensor
    (7) Clamp
    (8) Air Intake Resonator
    (9) Air Intake Duct to Throttle Body
    (10) Mass Airflow (MAF) Sensor
    (11) Isolator
    (12) Air Cleaner Housing Lower Assembly
    (13) Front Retaining Clips
    (14) Air Filter Element Frame
    (15) Air Filter Element
    (1) CKP Mounting Bolt
    (2) CKP Mounting Location
    (3) Crankshaft Position Sensor (CKP)
    (1) HO2S Bank 2 Sensor 1
    (2) HO2S Bank 2 Sensor 2
    (3) HO2S Bank 1 Sensor 2
    (4) HO2S Bank 1 Sensor 1
    (1) Evaporation Canister Location
    (1) PCM Location
    (1) Fuse Block #1
    (2) Fuse Block #2
    Coolant level Sensor
    101,226
    *-02 AN is equal to 1/8 in.
    * -03 AN is equal to 3/16 in.
    *-04 AN is equal to 1/4 in.
    * -06 AN is equal to 3/8 in.
    * -08 AN is equal to 1/2 in.
    *-10 AN is equal to 5/8 in.
    * -12 AN is equal to 3/4 in
    *-14 AN is equal to 7/8 in.
    *-16 AN is equal to 1 in.
    * -20 AN is equal to 1 1/4 in.
    * -24 AN is equal to 1 1/2 in.
    *-32 AN is equal to 2 in.
