Thread: RPO's F-body 93 - 02
    The Man
    Cape Coral , Florida
    19
    RPO's
    i pulled these RPO Codes for F-Body's from 93-02
    if you wanted to put them somewhere for easy use like an archive. i know this isnt an F-body site but i thought it might be useful if it isnt already here . i dont think i am missing anything , but who knows i am only human and i can make a mistake , but its doubtful ).Anyway here it is if you wanted to make it a sticky or anything.
    A31 power windows
    AAA factory tint
    AC3 power 6 way, bucket, driver
    AG1 Adjuster, 6-Way Power, Driver Seat
    AG4 Adjuster, 2-Way Manual, Driver Seat
    AR9 front bucket, european style, passenger & driver
    AH3 Adjuster, 4-Way Manual, Driver Seat
    AK5 Restraint System Front Seat, Inflatable, Driver and Passenger
    AN4 Restraint Provisions, Child
    AQ9 Seat, Passenger and Driver, Recline
    AUO Lock Control, Remote Entry
    AUD remote keyless entry
    AU3 Lock, Side Door, Electric
    A31 Window, Power Operated, Side
    A90 Lock, Rear Compartment Lid, Remote Control, Electric
    B35 Floor Mats, Rear, Carpeted Insert
    B84 Exterior Molding, Body Side
    CC1 Roof Hatch, Removable Glass Panels
    C41 HVAC System, Heater
    C49 Defogger, Rear Window Electric
    C60 HVAC System, Air Conditioner, Manual Control
    DD9 Mirror, Outside, LH & RH, Remote Control, Electric, Breakaway, Painted
    DE4 Sunshade, Removable Hatch Roof
    DG7 Mirror, Outside LH & RH, Remote Control, Electric, Painted
    DL5 Decal Roadside Service Information
    D35 Mirror, Outside LH Remote, RH Manual, Painted
    D5X gear-driven speedometer
    D81 "GT" raised spoiler
    D82 Paint Special
    FE2 Suspension system, Ride handling
    FE9 Certification Emission, Federal
    F41 Suspension System, Firm Ride Handling, Front and Rear
    GU2 Axle, Rear 2.73 Ratio
    GU3 auto tranny,
    GU4 Axle, Rear 3.08 Ratio
    GU5 Axle, Rear 3.23 Ratio
    GU6 Axle, Rear 3.42 Ratio
    G80 Axle, Rear Posi-traction (Limited Slip)
    G92 performance suspension package
    ILD Trim, Interior Design
    IL2 Trim, Interior Design
    IPB Trim, Interior Design
    IP2 Seat, Leather Sport Front Bucket, Driver & Passenger, Reclining
    J41 Brake System, Power, Front Disc, Rear Drum, Cast Iron
    J65 Brake System, Power, Front and Rear Disc
    KC4 cooling system, engine oil
    KG9 Generator, 140 Amp
    K05 Heater, Engine Block
    K34 Cruise Control, Automatic Electronic
    K68 Generator, 1 05 Amp
    LT1 Engine, 5.7L (V8) MFI
    LS1 Engine, 5.7L (V8) MFI
    L36 Engine, 3.8L (V6) MFI
    MD8 THM 700 R4 auto tranny
    MM5 Transmission, 5-Speed Manual (Merchandising Option)
    MM6 Transmission, Manual, 6-Speed, Borg Warner, 65mm, 2.66 1st, 0.50 6th, O/D
    MN6 Transmission - 6-Speed Manual (merchandising Option)
    MXO Transmission - Automatic O/D (Merchandising Option)
    M30 Transmission - Automatic, 4-Speed, 4LE, Electronic
    M49 Transmission, Manual, 5-Speed, Borg Warner, 77mm, 3.75 1st, 0.76 5th, O/D
    NA5 emission, federal, tier 0
    NB6 Emission System, California Requirements, Tier 1
    NC3 Tailpipe Modifications
    NF2 Emission System- Federal Requirement, Tier 1
    NK3 Steering Wheel, Sport, Soft Rim, Simulated Leather
    NP5 Steering Wheel, Leather Wrapped
    NW9 ASR Traction Control
    N36 Steering Wheel, 4-Spokes, Sport
    N60 Wheel, Aluminum, Painted
    N92 Cover, Wheel, Bolt-On
    N96 Wheel, 16x8, Cast Aluminum
    N98 Wheel, Chrome, Var 2
    P05 Wheel, Chrome, Var 1
    P08 Cover, Wheel, Super Deluxe
    PW7 16 x 8 alloy wheels
    QA7 Wheel, 16x7.5, Aluminum
    QB3 Wheel, 16x7.5, Steel
    QEA Tire, P215/6OR16 BW R/Pe ST TL AL2 94T
    QFZ Tire, P24515OZR16 BW R/PE ST TL AL3
    QII Tire, P21516OR16 BW R/PE ST TL AL3 94H
    QLC Tire, P24515OZR161N BL R/PE ST TL HW4
    STE Plant Code-St. Therese, PQ, GM of Canada
    TR7 Headlamps, Automatic Control Leveling System
    T39 Lamp Turn Signal, Auxiliary
    T43 Spoiler, Rear
    T61 Lighting- Daytime Running
    T96 Lamp, Fog
    UA6 Theft Deterrent System
    UB3 Instrument Cluster, Oil, Coolant, Temperature, Volts, Trip Odometer, Tachometer
    UK2 Lever, Directional Signal, Multifunction
    UK3 Electronic System Accessory Control
    UL0 AM/FM Cassette ETR 200 Watt Monsoon Sound System w/cassette
    UN0 AM/FM Cassette ETR 200 Watt Monsoon Sound System w/CD player
    UN6 Radio, AM/FM stereo, Seek/Scan, Auto Reverse Music Search Cassette, Clock, ETR
    UQ0 Speaker System 4, Dual Front Door Mounted, Standard Range Quarter/Shelf
    UU8 Radio, AM/FM Stereo, Seek/Scan, Auto Reverse Music Search Cassette, HPS, Clock, ETR
    U1A CD radio, 10 speaker
    U1C Radio, AM/FM Stereo, Seek/scan, Compact Disc, Clock, ETR
    U1S 12 Disc Compact Disc Changer
    U1T Radio, AM/FM Stereo, Seek/Scan, Compact Disc, HPS, Clock, ETR
    U18 Speedometer Instrument Kilometers
    U19 Speedometer Instrument, Kilometers and Miles, Kilometer Odometer
    U62 Speaker system 4, Dual Coax Front, Dual Coaxial Package shelf
    U65 Speaker system 5, Dual Front Door Mtd, Dual Ext. Range Panel, Single Rear Compartment
    U73 Antenna, Fixed
    U75 Antenna, Power
    UT6 AM/FM stereo, seek/scan, auto rev
    UW2 speaker system, 10, quad front door mounted, dual rear sail panel
    V73 vehicle statement, US/CANADA
    VG8 Label, Vehicle, Notice to Buyer
    VH5 Plate, Vehicle Information
    VK3 License Plate, Front Mount Package
    VM3 label information consumer, contains bumper impact standared
    VP6 Noise Control
    WS6 Performance Package - Formula/Trans Am
    WS9 model conversion, FORMULA
    WU8 SS Performance Package/Appearance Package - Camaro
    W51 Entertainment system - Radio, AM/FM-stereo, seek/scan, cassette, 4 Speaker system Standard Range
    W52 Entertainment System - Radio, AM/FM stereo, Cassette, Equalizer, 4 Speaker system - Coaxial
    W53 Entertainment System - Radio, AM/FM Stereo, Compact Disc, Equalizer 4 Speaker System - Coaxial
    W54 Entertainment System - Radio, AM/FM Stereo, Cassette, Equalizer, 10 Speaker System, Amplifier
    W55 Entertainment System - Radio, AM/FM Stereo, Compact Disc, Equalizer 10 Speaker System, Amplifier
    W57 Entertainment system - Radio, AM/FM stereo, Cassette, Equalizer, 4 Speaker system - Coaxial
    W58 Entertainment system - Radio, AM/FM Stereo, Compact Disc, Equalizer, 4 Speaker system - Coaxial
    W59 Entertainment system - Radio, AM/FM Stereo, Cassette, Equalizer, 6 Speaker System, Dual Front Door Tweeters/Woofers, Extended Range Shelf
    W66 Merchandised Package - Formula
    W73 Entertainment system - Radio, AM/FM Stereo, Compact Disc, Equalizer, 6 Speaker system, Dual Front Door Tweeters/Woofers, Extended Range Shelf
    Y81 Merchandised Package - Firebird
    Y82 Merchandised Package - Trans Am, Base Coupe
    Y83 Trans Am model
    Y84 Merchandised Package - Trans Am
    Y87 Merchandised Package - Performance Enhancement
    Z28 Merchandised Package - Special Performance
    Z49 Canadian Modifications
    01U Primary Color exterior, Special
    05Q Molding Color, Cyclamen
    O5U Primary Color Exterior, Cyclamen
    1LE Performance Package Components
    101 Interior Trim - Arctic White
    1OT Top Color - Arctic White
    102 Trim Combination Leather, Arctic White
    1OQ Molding Color - Arctic White
    1OU Primary Color - Exterior, Arctic White
    12B Trim Combination - Cloth, Graphite
    12D Trim Combination - Cloth, Graphite
    121 Interior Trim - Graphite
    14B Trim Combination - Cloth, Dark Gray
    1SG Preferred Equipment Group
    28U Primary Color - Exterior, Navy Blue Metallic
    1SA option package 01
    1SC package option 03
    1SZ discount option package
    37Q exterior molding color, manta green metallic
    17P wheel color, silver mist metallic
    37U primary color, exterior, memphis blue metallic
    141 trim/leather combo
    17P wheel color; silver
    8TH rear springs
    9TH rear springs
    81Q molding color, bright red
    81U exterior color, bright red
    101,216
    This looks like a good spot for this information!
    Thanks
