Results 1 to 7 of 7
Thread: turn signal flasher?
    13,611
    Question turn signal flasher?
    I assume to gain access to the turn signal flasher one has to remove all the under dash cowling? seems that nothing is viable from under the dash.
    13,611
    ok removed under steering column panel but there is no flasher unit anywhere that I can see.
    13,611
    13,611
    this signal flasher is no where to be found under the dash.
    oh
    15,769
    it's not under the driver side... it's either in the center or the passenger... there's 2 blinker modules (turn signals and emergency flashers)... i forget which one is where.
    101,212
    Look around the steering column. It's near that and it's up to make it a PITA to find. You can get to it easy enough, you just gotta find the little bastage.
    Elmer
    101,212
    try this
