Thread: 2007 C6 Corvette Grounds
    101,226
    101,226
    Engine 1
    (1) Repeater Lamp - Left (T90)
    (2) Suspension Damper - LF (F55)
    (3) G101
    (4) C119
    (5) Marker Lamp - LF
    (6) Fog Lamp - LF
    (7) Inflatable Restraint Front End Sensor - Left
    (8) Inflatable Restraint Front End Sensor - Right
    (9) Ambient Air Temperature Sensor
    (10) C131 to Underhood Lamp (if equipped)
    (11) Horn Assembly
    (12) Fog Lamp - RF
    (13) S102
    (14) C120
    (15) Marker Lamp - RF
    (16) C102
    (17) G102
    (18) Suspension Damper - RF (F55)
    (19) Hood Ajar Switch
    (20) Fuse Block - Underhood C1
    (21) Repeater Lamp - Right (T90)
    Engine 2
    (1) A/C Refrigerant Pressure Sensor
    (2) Hood Ajar Switch
    (3) C166
    (4) C186
    (5) C168 (F55)
    (6) Windshield Washer Fluid Level Switch
    (7) Windshield Washer Fluid Pump
    (8) Headlamp Washer Fluid Pump (CE4)
    (9) S101
    (10) S103
    Engine 3
    (1) C139
    (2) Heated Oxygen Sensor (HO2S) Bank 2 Sensor 1
    (3) Manifold Absolute Pressure (MAP) Sensor
    (4) Throttle Body Assembly
    (5) Evaporative Emission (EVAP) Canister Purge Valve
    (6) A/C Compressor Clutch
    (7) C160
    (8) Suspension Position Sensor - RF
    (9) Fuse Block - Underhood C2
    (10) Engine Control Module (ECM) C3
    (11) Engine Control Module (ECM) C2
    (12) Engine Control Module (ECM) C1
    (13) C184
    (14) C182
    (15) C180
    (16) C186
    (17) Engine Oil Level Switch
    (18) Crankshaft Position (CKP) Sensor
    (19) Heated Oxygen Sensor (HO2S) Bank 2 Sensor 2
    (20) Fusible Link
    (21) G106
    (22) Starter Solenoid
    (23) Starter Crank Voltage
    (24) Knock Sensor (KS) Bank 2
    Engine 4
    (1) Generator
    (2) C140
    (3) Heated Oxygen Sensor (HO2S) Bank 1 Sensor 1
    (4) G107
    (5) Heated Oxygen Sensor (HO2S) Bank 1 Sensor 2
    (6) Knock Sensor (KS) Bank 1
    (7) G105
    (8) Wheel Speed Sensor (WSS) - LF
    (9) Suspension Position Sensor - LF
    (10) Camshaft Position (CMP) Sensor
    (11) Variable Effort Steering Actuator
    (12) S195
    (13) Electronic Brake Control Module (EBCM)
    (14) Brake Fluid Pressure Sensor
    (15) Generator
    Engine 5
    (1) C116
    (2) C180
    (3) C182
    (4) G104
    (5) Fuse Block - Underhood C3
    (6) Fuse Block - Underhood C4
    Passenger Floor
    (1) S217
    (2) Relay Block - I/P
    (3) G202
    (4) S234
    (5) S202
    (6) Splice Pack SP208
    Overhead Convertible
    (1) C382
    (2) G302
    (3) C380
    (4) Door Latch - Driver
    (5) Folding Top Cover Pull Down Actuator (CM7)
    (6) Rear Compartment Courtesy Lamp - Right
    (7) C455
    (8) C433 (CM7)
    (9) Rear Compartment Lid Latch Assembly
    (10) Keyless Entry Antenna - Rear Compartment
    (11) Rear Compartment Courtesy Lamp - Left
    (12) Fuel Door Release Switch
    (13) Door Latch - Front Passenger
    (14) G301
    (15) C377
    (16) C379 (AAB)
    (17) C375
    Overhead Hdtop Coupe
    (1) C382
    (2) C380
    (3) G302
    (4) Door Latch - Passenger
    (5) Keyless Entry Antenna - Rear Compartment
    (6) Rear Window Defogger Grid C2
    (7) Rear Compartment Courtesy Lamp - Right
    (8) C455
    (10) Rear Compartment Courtesy Lamp - Left
    (11) Fuel Door Release Switch
    (12) Rear Window Defogger Grid C1
    (13) G301
    (14) C377
    (15) C379 (AAB)
    (16) C375
    IP Harness Steering Column
    (1) C503
    (2) Splice Pack SP205
    (3) S237
    (4) S211
    (5) S207
    (6) S219 (U3Z)
    (7) S204
    (8) S205
    (9) Console Trim
    (10) S221
    (11) S200
    (12) G201
    (13) S201
    (14) C501
    Fuel Tank Transmission
    (1) Wheel Speed Sensor (WSS) - RR
    (2) Vehicle Speed Sensor (VSS)
    (3) Reverse Switch 1
    (4) Reverse Switch 2
    (5) C420
    (6) Fuel Tank Pressure (FTP) Sensor
    (7) Fuel Level Sensor - RH
    (8) C460
    (9) Suspension Position Sensor - RR (FE2)
    (10) G401
    (11) C439
    (12) Wheel Speed Sensor (WSS) - LR
    (13) Suspension Position Sensor - LR (FE2)
    (14) Transmission Fluid Temperature (TFT) Sensor (KNP)
    (15) C459
    (16) Skip Shift Solenoid (JL5)
    (17) Reverse Lockout Solenoid
    (18) C460
    (19) Fuel Pump
    (20) Fuel Tank - RH
    (21) C168
    (22) C184
    (23) Electronic Suspension Control (ESC) Module
