Results 1 to 6 of 6
Thread: New Gauge/Panel Setup
    Jul 2005
    West Bath, Maine USA
    74
    Decided to change things up a bit, I got a Trick Performance V Series Gauge/controller from Nitrous Outlet to add safeties to my Nitrous setup. I created a new panel from lessons learned this year, LOL the major change is the stage indiction lights in the ashtray area...pretty useless, so I moved those to the pillar pod.
    Anyways just wired it up and got everything workin...
    Here are some pics.
    New Gauges in Place
    New Nitrous Panel...deleted the gauge power switch the EFI tune switch (hard-wiring that to be automatic tune switching), deleted the heater (Heater is controlled by the new Trick Performance Black Gauge), moved the LC-1 Cal button to cab vice the engine bay.
    Cleaned up the wiring on the back side of the new panel
    Here is the new gauge with the WB inputs and Bottle Pressure readout
    You can switch the display to AFR only (or Boost) as well. You can configure the Gauge to fire the nitrous only when within safe AFR's.
    It's a BLOOD BATH!!!! QWIKLS1's Avatar
    Tempe, AZ- (Not near Palos Park IL)
    68,277
    101507
    Dayum beer.
    Top notch as always.
    Registered Member jwatson's Avatar
    Aug 2006
    177
    Very nice
    Telling it how it is..... red metal's Avatar
    Sep 2004
    Arnaudville, LA
    2,735
    very clean Beer.....
    Things are well TARZAN's Avatar
    Greater Memphis Area
    16,103
    clean stuff, post pics of the panel installed
    -Will
    Jul 2005
    74
    Here ya go
    Lid closes and hide everything nicely.
