Page 9 of 12 FirstFirst 123456789101112 LastLast
Results 481 to 540 of 692
Thread: Finally got my new daily beater today!! (Edit: Train Horns FTW!!)
  1. #481
    Registered Member The Beatles's Avatar
    Marietta, Ga
    12,491
    2000
    Gamertag: TransAmFTW
    woot, i love when this thread gets updated!!
  2. #482
    Registered Member Immortal's Avatar
    Mar 2007
    2,005
    You really just need to find an allspark and get on with this show already.
  3. #483
    17,616
    So today she turned 340,000 miles and I replaced the washer diverter valve again
    I had replaced it once back in 2009 and it started giving me the exact same symptoms randomly since last week (rear washer working when I flip rear on, rear working when I hit front button, both working slowly or not at all, etc.)
  4. #484
    17,616
    Finally got around to flipping the solenoid pack and adding all new cables to the rear winch
  5. #485
    Ride and Dine! FirehawkNS's Avatar
    Charlotte, NC
    26,155
    2025
    Obligatory post to show this thread is still appreciated so more upgrades get posted down the line...
  6. #486
    always broke honky 5.7Phoenix's Avatar
    Feb 2005
    Austin, TX
    4,512
    300
    How capable are the Lexus equivalents to your generation Landcruiser? I have been seeing a few around Austin as well as a few Landcruisers. Also, what does the vent on the back pillar do on the ones the generation newer than yours?
  7. #487
    17,616
    Quote Originally Posted by 5.7Phoenix View Post
    The two are practically identical with very minor differences (kinda like comparing a Sierra to a Silverado)
    The LX got better leather, body cladding, softer shocks, a 90's tech mobile phone and a slightly better sound system.
    I actually installed LX shocks all around on my TLC because I wanted a softer ride.
    The driver's side rear sliding window is fixed on the LX due to the phone antenna while all 4 slides on the TLC
    The subwoofer and CD changer is built into the center console while the TLC's had the subwoofer mounted in the right rear corner.
    The good thing about the LX450's is that the majority of them were serviced at the dealer and they usually have good service records, however, they were only made for two years which makes them a little harder to find.
    They simply vent the cabin
    When the HVAC is set to fresh air, it sucks in air from the front and the excess is forced out the vents
    When set to recirculate, the vents stay closed.
  8. #488
    17,616
    Dash cam caught a Heep in front of me blowing up while at the BK Drive-Thru
  9. #489
    17,616
    Took the family movie hopping last night and karma kinda bit me in the arse cause on our way home, my charging light came on
    Drove 40 minutes home with the lights, wipers and heater going without issue
    Then drove about an hour in traffic to my uncle's shop on the Island and found the output lead for the alternator had fried
    Wiggled and it snapped right at the output terminal
    Replaced both the main charging lead and the fuse panel lead with 6Ga. cables.
    Then hacked the old ring terminal and used it as a locking ring washer.
    Wasn't able to get a new fusible link, but everything seems to be working fine
    I had panned on driving to Orlando this morning, but this gave me a reason to stay another night, so off to the movies we go again
  10. #490
    17,616
    OK, so Friday I decided to replace the bleeder valves on all four calipers and the one on the LSPV
    They were a bit tough to loosen the last time I bled the brakes, so I just ordered up new ones and had been putting it off for about the last 5 months
    Had to heat them up a bit with a torch, but I managed to remove them all
    Toyota doesn't sell the valve fo the LSPV separately, so I just picked up a speed bleeder, which, unfortunately, was a little too short, so I just cleaned out the old one and stuck in back in there
    Bled the brakes and all was good until the next morning when I felt a hard pedal
    Bled the brakes again (both vacuum bleeding and 2-man bleeding), but it still had the same hard pedal
    Turns out she needs a booster now
    I figure it was probably on its last leg and just gave up from all the bleeding
    Got a new one on my desk and not really looking forward to replacing it
    It's only a few bolts, but it's a tight squeeze under the dash for my fat arse
  11. #491
    17,616
    OK, followed the FSM to make sure the booster was the culprit and although it passed the "Operation Check", it didn't pass the "Air Tightness Check"
    When I shut the motor down with the pedal depressed, after a few seconds, it just suddenly pushes back up with break leg force
    My local dealer wanted $400 for a new one, but that was way too much cheese, so I just ordered a new OEM hose and as much as I hated to do it, I had VatoZone drop off a reman
    I was able to R&R without removing any lines
    The lines were flexible enough to give me more room than I needed
    The hardest part for me was actually squeezing my fat arse under the dash to put the top left nut back on
    I refused to take off the Cruise Control box, which would've made it much easier, but I'm too lazy (and stubborn) to walk all the way back to my tool box to grab a 10mm socket
    All is well and the whole job took about 40 minutes
  12. #492
    LIFE IS GOOD HybridZ28's Avatar
    DFW, Texas
    28,816
    310
    Awesome rick. Did that fix the problem? You didn't say or maybe I missed it lol
    Edit - you said all is well. Good deal, Never mind lol
  13. #493
    17,616
    Yeah, everything is running tip top again.
    Should be hitting 355k sometime today or tomorrow (depending on how much I drive the Road Runner)
  14. #494
    DFW, Texas
    28,816
    310
    Wow. Crazy man
  15. #495
    Charlotte, NC
    26,155
    2025
    That is awesome!! I want to see this thing go to 500k....get to driving Rick!
  16. #496
    6,799
    490
    Should have used that as an opportunity to do a hydro-boost swap.
  17. #497
    17,616
    Quote Originally Posted by BigKID View Post
    Being a stock motor, I've got no problem with vacuum at idle, so there really isn't a need for hydro
    A few guys that did 4BT or 6BT conversion went with hydro-boost and it worked fine, but I actually have more faith in the stock system
    My buddy had a hydro-boost setup on his Rustang and nearly took out my T/A in a back road drag race when he threw a belt and lost all braking
    Not that I'd have that problem since my P/S pump is gear driven
  18. #498
    17,616
    New hose just arrived
    Old hose held pressure fine, but showed some cracking, so I ordered one anyways
  19. #499
    get sum! dingle's Avatar
    tvlle flo rider
    30,898
    2292
    Steam ID: STEAM_0:0:16581731
    Nice keychain Rick.
  20. #500
    17,616
    Quote Originally Posted by dingle View Post
    Nice keychain Rick.
  21. #501
    426HEMI's Avatar
    Maryland
    94,664
    2275
    Still take $3k for that RR? I have the 'want a weekend toy' bug now.
  22. #502
    17,616
    Quote Originally Posted by 426HEMI View Post
    Sure
    The one I'm holding in my hand, right?
  23. #503
    Damn Dog! Mako's Avatar
    4,608
    Nice, where do you get those from? I would like one of a C5
  24. #504
    17,616
    Quote Originally Posted by Mako View Post
    I got them from a collector on EBay many years ago dirt cheap ($400)
    He still stocks many different authentic train horns and whistles if you're interested
  25. #505
    On the boss's desk Dr. Berman's Avatar
    50,671
    2025
    i hope one of us misread his question and you didnt pay $400 for a hot wheel
  26. #506
    17,616
    Sorry, for some reason I thought he was asking about the horns
    As for the key chains, just find a matching car, drill a hole and rivet a chain to it
  27. #507
    4,608
    Quote Originally Posted by 98 SNAKE EATER View Post
    Sorry, I was talking about the keychain. I want one to match my C5
  28. #508
    17,616
    The surveillance system picked up a little footage during an interesting ride home last week....
    Details here:
    http://www.ls2.com/forums/showthread...ive-home-today
  29. #509
    17,616
    A few teaser shots of the new roof rack I'm building
  30. #510
    Marietta, Ga
    12,491
    2000
    what happened to the old roof rack?
  31. #511
    DFW, Texas
    28,816
    310
    Quote Originally Posted by The Beatles View Post
    i don't think it's made out of aluminum, he might be experiencing some wear damage? Just my guess, i dunno LOL
    Looking good!!
  32. #512
    17,616
    Quote Originally Posted by HybridZ28 View Post
    Looking good!!
    Hit the nail right on the head
    Remember when I made the original rack, it was done on a budget and I used leftover EMT and cheap mild steel that was sitting in the back of the shop
    The EMT held up great over the years, but the square tubing has rusted badly from the inside out
    It's still on the roof, but I wouldn't go walking around on it like I used to
    I've been planning out a new hybrid design (aluminum and EMT, no raw steel) that's more user friendly and will remain rock solid for years to come
    I must say, welding galvy is NOT fun
    Even though I'm using a vacuum respirator, that smoke still manages to get to you
  33. #513
    4,608
    I really hate you.
    I wish I had half the skills you display.
  34. #514
    17,616
    Some of the laser work came in, so here are a few test fit shots
  35. #515
    DFW, Texas
    28,816
    310
    Do I sense some led lights going in behind the laser etched panels?
  36. #516
    17,616
    I was actually thinking about some El Tape
  37. #517
    DFW, Texas
    28,816
    310
    Woah
  38. #518
    17,616
    Just took the old rack off
    Truck feels so naked now
    I dunno how I'll get through the next week without train horns
  39. #519
    17,616
    OK, I pulled the trigger on a pair of flood beams for my bumper
    I figured if I was satisfied with the quality, I'd order a set of 5 for my new roof rack (still under construction)
    Did a test fit on the rack and it looks like I'll be splitting a couple of millimeters within the loop I made
    So now I'm on the hunt for 5 matching spot beams, but it's gunna bit harder than I thought cause the style is being phased out due to legal reasons with the HID logos on the front
  40. #520
    Banned chud's Avatar
    1,610
    97
    Drink milk.
  41. #521
    17,616
    Quote Originally Posted by chud View Post
    Drink milk.
    So I can have both a headache and the skwirtz
    No thanks
  42. #522
    PC Florida
    18,488
    Pics of it in water deep enough to need the snorkle?
  43. #523
    17,616
    Quote Originally Posted by speed_demon24 View Post
    I've had it half way up the windshield, but no pix, just useless dashcam video that looks as though I was rinsing a fishbowl
  44. #524
    17,616
    Notched some braces for the light loop
    Gotta wait until the other lights come in before I weld them up
  45. #525
    17,616
    New spots arrived earlier today
  46. #526
    17,616
    OK, the tube welding is done and the lights are all mounted up
    Gunna do one last test fit either today or tomorrow to mark the mounting points for the limb risers and once those are welded in, it's off to the spray booth
  47. #527
    IG: eightyfivesquared 70Chevelle's Avatar
    20,151
    1860
    Gamertag: Ls1Chevelle
    crocs and socks...
  48. #528
    17,616
    The sign of a beaten man, I know, I know
  49. #529
    Charlotte, NC
    26,155
    2025
    What brand lights are those? I wonder if they would work for replacements for my center foglight mod on the Z?
    01-02-12 Aviation Museum 225 by FirehawkNS, on Flickr
  50. #530
    17,616
    Fleabay 55 watt lights
    http://www.ebay.com/itm/350869935538...84.m1497.l2649
    They're actually pretty damn good quality for the money
    H3 bulbs
    Real Glass lens (not plastic)
    Metal housing
  51. #531
    17,616
    Test fit today
    Still gotta drill for the front mounts, weld up limb rise mounts, then size up the relay box and weld that too
    Should be in the booth this weekend if there's room
  52. #532
    The struggle owns me. MrFML's Avatar
    Dothan, AL
    4,860
    50
    Gamertag: MrFML
    How many Amps do all of those lights pull?
  53. #533
    17,616
    Quote Originally Posted by MrFML View Post
    7Amps for each of the 9" lights, which is actually less than the 100watt halogen spot lights they're replacing, even though they're MUCH brighter
    Not sure on the little ones, but I doubt they're even worth checking since they're less power than what I had previously
  54. #534
    Charlotte, NC
    26,155
    2025
    H3 bulbs
    Metal housing
    Not those, the big round ones.
  55. #535
    17,616
    Quote Originally Posted by FirehawkNS View Post
    Yikes, you plan on Rally racing your Camaro?
    Even though they're 9", they actually measure about ~10.5" and the housing for the HID controller makes the whole thing about the size of a 10 subwoofer, so you'd be cutting up the nose quite a bit if you want a flush fit
    Got those on EBay as well, but they're getting hard to find
    The ones with the red ring that say HID all around are no longer being made due to some legal reason
    The two mounted on the front bumper are flood beams and I got them from this EBay seller (who just happened to change the listing to the newer/uglier style they currently sell)
    http://www.ebay.com/itm/261336785412
    The ones on the rack are spot beams and I got them from Amazon, but the seller also switched his listing over to the newer/uglier style lights
    http://www.amazon.com/dp/B00DG1ZMY4/?tag=ihco-20
  56. #536
    17,616
    Threw her in the booth and got her coated on Saturday
  57. #537
    Clever Hogie Sammich's Avatar
    Fremont, CA
    11,764
    Steam ID: STEAM_0:1:26913449
    Big thumbs up!!! Awesome project and work!!
  58. #538
    Registered Member Checkmate's Avatar
    Virginia
    22,176
    Looks awesome. Can't wait to see it all together
  59. #539
    DFW, Texas
    28,816
    310
    love it, great job man
  60. #540
    17,616
    Rewired my winch cover lighting with waterproof LED strips and also wired up a pair of 9" HID flood lights
    Damn things are bright as hell already and I've got 5 more going on the roof
