Page 3 of 12 FirstFirst 123456789101112 LastLast
Results 121 to 180 of 692
Thread: Finally got my new daily beater today!! (Edit: Train Horns FTW!!)
  1. #121
    time for your annual... Dr. Lexus's Avatar
    NC
    13,562
    1616
    PSN ID: blunt_dissection
    man, I love this thread.
  2. #122
    Damn Dog! Mako's Avatar
    4,608
    I think I hate you even more now then I used to if thats possible
  3. #123
    Jan 2006
    543
    Whats the next mod? You need to do something to keep us entertained. I love this thread
  4. #124
    17,618
    Well, I didn't have much time to play with her today, but I did manage to install the auxiliary game inputs for the kiddies
    I'll try to get the wireless cam done tomorrow
  5. #125
    17,618
    OK, I forgot the wiring harness at home yesterday, so instead of installing the spy cams, I decided to bedline the bumpers and grille
  6. #126
    17,618
    OK, here's the center channel that showed up this morning:
    Don't let the fleamarket brand name throw you, it's basically a discontinued 7 speaker Clarion SRK5 that's been rebadged as a Pyle and sold for half price
    Had to hack the crap out of it and epoxy the two subs upsidedown (ghetto, I know), but it works just fine
    Tried it out on a jump box and it sounds great
    Gunna install the amp in the quarter panel tomorrow...
  7. #127
    17,618
    OK, since the HU has a karaoke mode with a mic input, I wired up a flush mount 1/4" input jack so we can sing along to Simon and Garfunkel
    It also doubles as a guitar input, so I can plug in my axe and jam to buckethead while driving
  8. #128
    PM me for BERMANS ADDRESS Hillbilly Deluxe's Avatar
    444 FM 1463 Rd Katy Tx
    75,776
    Lookin' good man!!
  9. #129
    17,618
    This is what happens when we get bored at my shop
    One of our bodymen saw me muckin around with the guitar, walks over and grabs it, then starts jammin out of nowhere
    http://www.youtube.com/watch?v=wznPd1zuzjY
    After that, he grabs the mic and kicks it with some karaoke
    http://www.youtube.com/watch?v=Hy3Qoa3mtCA
  10. #130
    4,608
    So, can I leave my car in your shop while you guys are bored for a while?
  11. #131
    17,618
    Sure
    I've been wanting to install a potato cannon to the roof of someone's car
    Anyhoo, I added another little sumthin sumthin to the cruiser today
    With the added weight of the rack and trailer, the rear springs have been sagging a bit
    I can't justify an expensive high lift at this time and the thought of losing the plush ride with a set of heavy duty replacement coils just didn't sit well with me, so I decided to add a set of AirLift helper springs
    This is what I started with (crossposted from an install thread, so please bear with all the details):
    I used a trans jack to control the rear end drop after unbolting the shocks with a 17mm socket.
    I lowered the rear slowly and checked for any stressed lines as it went down.
    All of the lines had enough slack except for the breather hose, so I yanked it:
    Then I unbolted the bumpstops with a 12mm socket and extension:
    A shot of the springs and stops removed:
    With everything pulled, I sanded the rusty high hats and gave them a good coat of rust control paint:
    Next, I drilled out the existing mounting holes to 3/4" using a Uni-Bit.
    I personally don't think this step is required, but since I'm a stickler for procedure, I followed the instructions to a tee:
    Then I deburred the hole, sanded the spring mount and coated it with rust control paint:
    After that, I gave the springs a good wash and checked for sharp edges that could damage the airbags:
    To keep the rubber seats in place, I taped them to the top of the springs:
    The new airbags just slid into place from the top of the springs:
    I then reinstalled the bagfilled springs:
  12. #132
    17,618
    With the new bags in place, I moved on to the airlines.
    I wanted easy, hidden access, so I chose the fuel filler:
    With the trim panel removed, I drilled a couple of holes and mounted the Schrader valves:
  13. #133
    17,618
    Next, I sized up the line running it through the chassis and down to the right airbag, leaving enough slack in the line for suspension movement:
    After making the first cut, I yanked the lines out and wrapped them in plastic loom to protect them from any sharp edges in the chassiswork:
    Then I attached the lines to the valves, aired them up to 25psi. and checked for leaks using soapy water and a spray bottle:
    With no visible bubbling, I reinstalled the trim panel and applied the safey decal on the inside of the fuel door:
    Then I slowly lowered the lift and made sure there was enough slack in the lines before zip-tying them in place:
  14. #134
    17,618
    Now, with 25psi., it definitely has a stinkbug look to it
    As per the instructions, I will drive it home like this and let it settle overnight, then check for leaks tomorrow and release some pressure until it's completely level
  15. #135
    4,608
    you come up with some of the coolest do it yourself projects. I am both humbled and jealous of you.
  16. #136
    Loss Prevention jsanderson's Avatar
    Bama that's where!
    1,699
    PSN ID: Jsanderson25
    ok snake, you have some of the coolest toys! I need a land cruiser like that!
  17. #137
    wigglewigglewigglewigglew iggleyeah
    Marklar's Avatar
    South Florida
    43,682
    damn man!
    rig the fuel door to sound the air horns to ward off potential fuel-stealers.
  18. #138
    MD
    9,928
    what exactly do you do for a living?
  19. #139
    Bama that's where!
    1,699
    can i leave my frontier with ya, and you just fix it up for me? of course I won't pay ya!
  20. #140
    17,618
    Originally posted by marklar
    damn man!
    I've already got them hooked up to the alarm, but I plan on adding a proximity sensor soon
    Whatcha want on it?
    Fibr Optic Frontier logo?
    Flamethrowers?
    Tater cannon turret?
    Anyhoo, here are some pix with a mild load and just 15psi.
    Still about an inch high in the rear, but you can I've bee told by other Cruiserheads that 12-13psi. is the normal pressure for leveling a full load
    Gunna load her up tomorrow with gear and the Golf Cart and see where she sits
  21. #141
    42,543
    Don't the train horns run off air? Why not a single source for horns + rear springs so you can auto-inflate from inside the cabin?
  22. #142
    17,618
    Too much to plumb going from the roof to the bags
    If the tanks were mounted underneath, I would've done that
    Besides, hooking up my work hose to the tank and leading it to the fuel filler just takes a couple of minutes anyways
    On a sidenote, the bags fill so quickly and use so little air that I'm thinking of just using a bicycle footpump to keep things simple
    Cause using the air from the tanks is like trying to inflate a beachball with 150+psi
  23. #143
    Registered Member 567234ta's Avatar
    Fort Smith AR
    7,138
    Raptr ID: na
    subscribed
  24. #144
    The Battery King of South Georgia SIK02SS's Avatar
    Brunswick, GA
    39,962
    2500
    Gamertag: SIK02SS
    what kind of compressor you running?
  25. #145
    17,618
    ViAir 450c
    Anyhoo, small update:
    I recently installed a winch up front
    Unfortunately, the weight brought the front end down a bit
    Can't afford a proper lift at this time, so I installed a set of 2" Metal tech spacers up front and leveled it off prett good
    After that, the rear needed a bit too much air to stay level when loaded, so I installed a set of 1.5" Slee spacers in the rear and it's now completely level at just 5psi (leaving me with plenty of adjustment pressure)
  26. #146
    Brunswick, GA
    39,962
    2500
    Gamertag: SIK02SS
    any plans for a belt driven compressor?
  27. #147
    Registered Member ATC350X's Avatar
    Iowa
    7,720
    PSN ID: nerdbutter
    Nice work!
  28. #148
    17,618
    Disney recently gave me a $h!tload of Whelen strobe light kits from their old security fleet vehicles, so I decided to add set to the Cruiser
    http://www.youtube.com/watch?v=CwDXRi1KJrE
    I wanted the switches within easy reach, but didn't want them to be an eyesore, so I put them right behind the gearshift under the hand brake...
    Main switch turns them on and the little momentary button changes the flash pattern...
    Anyhoo, here's a short video I put together...
    http://www.youtube.com/watch?v=Zus9WjfWALk
  29. #149
    Registered Member Scotty's Avatar
    31,204
    3000
    Damn amazing! I love the strobes!
  30. #150
    Balsa wood! Kata Skopos's Avatar
    MN
    31,458
    37
    the train horn
    gets me every time
  31. #151
    Registered Member LS1redline's Avatar
    Indy area
    7,086
    lol, you never fail to dissapoint. Looks good!
  32. #152
    MN
    31,458
    37
    so waht else do you have planned for it?
  33. #153
    17,618
    Swing out spare carrier (Left), swing out ladder with cooler/jerry can holder (Right), hidden rear winch, etc., etc., etc.
  34. #154
    75,776
    Rick, before you build a swing out tire carrier...Ive seen one that not only swings, it also folds down to make the unloading the rear tire easier. It had a dual latch system...I think I originally saw it on Pirate, and then a friend of mine saved the pics so he could copy the design. Im pretty sure it was in the Hardcore Jeep section.
    Btw, wanna help me come up with a semi-lightweight, yet fuctional trail trailer for me to tow behind my crawler?? Im not exactly sure how I want to do it yet. Im thinking for dimensions its gotta be 6x8 (big enough to sleep in if needed), fold down or removeable sides...somewhere around 3ft tall. Maybe some sort of integrated fuel reserve (25ish gallons) built into the underside of it to keep the center of gravity low. It'll ride on 35" BFG Mud T/A's. Think about it for a few days and see what other ideas you could come up with.
    Lovin' the 'cruiser The spacer lift makes it look really good, not to mention the airbags for the load carrying capacity.
  35. #155
    get sum! dingle's Avatar
    tvlle flo rider
    30,899
    2292
    Steam ID: STEAM_0:0:16581731
    I can't believe you didn't wire it into your rally lights...
    shit as usual Rick!
  36. #156
    17,618
    This is what I have in mind
    But it will be built on the OEM crossmember and have a swingout jerry can holder built into the ladder bar
    I have 26 sets left
    Gimme some time and you'll probably see them on the Kei truck and Golf Cart
  37. #157
    17,618
    OK, so I'm sizing up another kooky Cruiser accessory
    Not giving any details yet, but here's what I started making yesterday
    more to come....
  38. #158
    ▲▲▼▼◄►◄► B, A, Start Firehawk's Avatar
    6,545
    225
    Gamertag: Iron Condor Z
    Man you must live at Skycraft.
  39. #159
    17,618
    I've had some of their workers ask ME for help finding stuff there
  40. #160
    Registered Member Checkmate's Avatar
    Virginia
    22,176
    Cool mini-projects. When are you going to build a turbo kit for it, i'm sure with all the weight it is starting to feel slower.
  41. #161
    Fort Smith AR
    7,138
    Raptr ID: na
    such an awesome ride, i cant wait to see this project done.
  42. #162
    Dangerzone! BigT's Avatar
    Frozen Tundra
    56,840
    775
    Gamertag: Agent Johnson25
    I feel soo sorry for your wife bro
  43. #163
    MN
    31,458
    37
    so waht is it?
  44. #164
    17,618
    so waht is it?
    Gimme some time as I still have some parts on order
    Anyhoo, I finally got around to fixing the range on the OEM alarm
    Seems Toyota took the antenna wire for the alarm brain and just coiled it up around a harness under the dash, giving me a whole 10 ft. of remote range
    So I hacked it, soldered in a new wire, ran it up the driver side D-piller and around the front of the headliner to the passenger side and back to the C-pillar
    Now I get about 300 ft. and I have yet to replace the old battery that's been in the remote since I bought the truck 2 years ago
    Here's a test video
    http://www.youtube.com/watch?v=cLAwqft3A-o
    Can't wait to see how far she'll go with a new battery
  45. #165
    Fort Smith AR
    7,138
    Raptr ID: na
    hahaha man that would make me jump about 5 foot if that went off near me.
  46. #166
    Touchdown California!!! SadbutTrue's Avatar
    Los Angeles
    22,385
    3525
    PSN ID: sadbuttrue999
    god this thread makes me feel lazy
  47. #167
    Los Angeles
    22,385
    3525
    i do agree though, its time for some engine mods
  48. #168
    17,618
    LOL
    We'll, I've had my eye on a TRD S/C, but I don't think that will happen anytime soon
    She already known for being a gas hog
    An S/C will mean a little more pep, but high test fuel instead of regular
    Anyhoo, I got sme more useless goodies installed
    After a little test fitting, I realized my switch panel took up a bit too much space, so I downsized the main block by using individual jacks and extended the cables so I could tuck them away neatly in the passenger side kickpanel
    So I ripped her apart for the umpteenth time
    Then I installed front and rear bumper cams
    Added a mainswitch and relay for the cams...
    As well as a push button switch for activating the reverse sensing input to feed the HU without switching the rear screens and disturbing the passengers movie time...
    So basically, the knob switches from camera to camera rather than just a reverse cam
    The other inputs will be for interior cams, a pan/tilt dome cam and one wireless cam that I'll mount on my R/C crawler so I can drive by monitor for bush excursions
    Still on the lookout for a decent 30fps automatic DVR that's small enough to fit behind the glove box
  49. #169
    17,618
    Pic from the day I brought her home
    Pic from today
    I lov this truck
  50. #170
    this is our year :hs: silverSS's Avatar
    26,240
    175
    100k miles in 28 months?
  51. #171
    17,618
    Yeah, you DON'T want to see my gas bills since I've had this thing
  52. #172
    Registered Member puckerth's Avatar
    Central NY
    9,782
    PSN ID: OgieO
  53. #173
    161,771
    3804
    that's almost as many as I put on the camaro I had in HS. Nice!
  54. #174
    17,618
    After more than a couple years, the rack is starting to show a bit of rust, so I yanked it
    Gunna weld up a few additions before coating it with epoxy primer and possibly bedliner
    Also, my low buck mailbox did it's job perfectly, keeping all the electronics and compressor looking new
    But I'm sick of people constantly asking me about it, so I'll be replacing it with a toolbox
    Gunna be a long week driving with no train horns
  55. #175
    17,618
    Did a little more stripping today
    Forgot I pulled the running boards and fell face first when I got out after a drive
  56. #176
    what u doing with your fenders?
  57. #177
    17,618
    Bedliner
  58. #178
    17,618
    Ok, I'm done for the night (and high as a kite.......weeeeee!!)
  59. #179
    17,618
    Back together
  60. #180
    NC
    13,562
    1616
    you're not helping my growing desire to sell the SS and pick up a Land Cruiser or 4runner.
