1. Carefully lift up the dash pad in front of heater vent (2 velcro pads) and then pry up the pin (lift gently, they will come) holding the pad to the right of the sensor so you can reach the sensor.
2. Twist and pull the sensor out of the holder and pull it off the 2 wire lead and replace the sensor with one piece of wire plugged into the two pins(# 3 in pic) in the plug and tape the plug up and put it back under the pad.
3. Push the pad pin and velcro back down and you now have no more auto popup headlights.
WARNING: you now must turn on your own headlights when it gets dark
