Starter Motor Replacement 5.7L V8
Removal Procedure
Important
This vehicle was designed for starter mounting without shims. However, if single or double shims have been added to correct a noise or engagement condition, reinstall the shims in their original location to ensure proper pinion-to-flywheel engagement.
  1. Raise and suitably support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
  2. Remove the left side oxidation catalytic converter. Refer to Oxidation Catalytic Converter Replacement in Engine Exhaust.
    Object Number: 211621  Size: DEFAULT
    Click here for detailed picture of above image.
  3. Remove the starter motor bolts.
  4. Lower the starter motor.
    Object Number: 211617  Size: DEFAULT
  5. Remove the engine wiring harness starter lead nut.
    Object Number: 211595  Size: DEFAULT
  6. Remove the positive battery cable to starter motor nut (3).
  7. Remove the starter motor.
Installation Procedure
  1. Install the starter motor.
  2. Install the positive battery cable to starter motor nut (3). Tighten
Tighten the positive battery cable to starter motor nut (3) to 10 N·m (89 lb in).
  1. Install the engine wiring harness starter lead nut. Tighten
Tighten the engine wiring harness starter lead nut to 2 N·m (18 lb in).
  1. Raise the starter motor.
  2. Install the starter motor bolts. Tighten
Tighten the starter motor bolts to 50 N·m (37 lb ft).
  1. Install the left side oxidation catalytic converter. Refer to Oxidation Catalytic Converter Replacement in Engine Exhaust.
  2. Lower the vehicle.
